Question about Agri-Fab AgriFab Soft Top MowNVac
I am removing the blower fan from the 1'' shaft of a Briggs & Stratton 5 hp engine. I have already removed the retaining bolt & washer. Now how to I get the fan off the motor shaft?
  • 101 Answers
You may need a puller like a pulley puller or something like that if you look at the shaft it should have a convex spot in the middle for the puller to rest on
Posted on Sep 29, 2009
What are the torque specs on intake manifold on Briggs & stratton
if there is thread locking compound on bolt or threads it must be removed, use a tap to clean the threads and a wire brush to clean the bolts. Use a thread locking compound (blue) when reassembling, torque the bolts to 30 ft. lbs. alternating bolt to bolt in 7-10 lb. increments. Recheck the torque after the engine has been ran up to op temp.
Jul 17, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Removal of carburator from model 303447-0446-01 engine
How can I remove the drive shift pulley on a18hp Briggs & stratton engine
Feb 05, 2014 | Briggs & Stratton Briggs Stratton Intek V...
How do you remove the starter on Briggs & stratton V-twin 23 hp
You may need to remove the engine top cover to get at it maybe not...It is attached at the top of your engine where the fly wheel and fan are located..it spins the flywheel..if your engine is vertical it will be vertical if horizontal likewise.it normally has only two mounting bolts and a small wire or two..just remember where the small ones go..pretty much a easy job make sure you disconnect the battery or you will get sparks at the starter...good luck
Jul 23, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton 18 hp v-twin engine surges while running.
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Jul 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Agri-Fab AgriFab Soft Top MowNVac Logo
118 people viewed this question
Top Agri-Fab Garden Experts
Joseph Mueller
Joseph Mueller
David Ellis Rhea
Ray Smythe
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
