Question about Roper RAS8445KQ Top Load Washer
I have a roper washer,used, water keeps running till it overflows. checked hoses and they are not cloged. this happenes even when its unplugged.
    Sergeant:
  • 197 Answers
One to things
1 water solenoid valve faulty
2 blocked water pressure switch reservoir
i think its the first, turn off the water and replace it and the power
Posted on Sep 29, 2009
  • 61 Answers
Replace mixer valve
Posted on Sep 30, 2009
Water is cold
2 THINGS i WOULD CHECK ARE THE WATER TEMP SWITCH AND THE WATER INLET VALVE. LASTLY SOME MODELS ALSO HAVE A THERMISTOR U WILL NEED TO CHECK IT AS WELL.
TRY SWITCHING THE HOT AND COLD HOSES AND SEE WHAT HAPPENS,
READ THIS: The other item to check would be your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board. You can also do a live volt test to see if it is getting the full 120 current, but be sure to unplug unit before testing as this is a live test.
Also another trick to check the water valve, is to first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. I
Apr 06, 2016 | Dryers
How do i stop machine from filling up with water till it overflows
Sounds like you need to replace the water setting switch.
Oct 13, 2014 | GE WJSR2070B Top Load Washer
Hi I keep getting an error message "F27" on my
F27 OVERFLOW CONDITION
If the overflow contact on the pressure switch is closed for more than 60 seconds, an Overflow Condition occurs. In an
overflow condition, the door remains locked and the drain pump runs constantly, even if PAUSE/CANCEL is pressed twice and the display is cleared. Turn off hot and cold water faucets and unplug the unit before servicing.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, water inlet value, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Check for drain pump failure.
6. Check the inlet valve for proper shut off.
7. Check the pressure switch for proper operation.
Aug 31, 2011 | Bosch Axxis WFL 2060 Front Load Washer
The washer leaked water. It is about 8 yrs old and was working just fine til tonite. It didnt leak from the supply hoses or drain hose, I tipped it over and the outside of the drum was wet like it...
If it looks like the water overflowed then it could be a bad pressure switch the way to test it out is just fill it with water and set the washer on small load if it continues to put in water past the small load setting then you have a bad pressure switch
AST Appliance Repair in San Diego
Jan 17, 2011 | Roper RAS8445KQ Top Load Washer
Water continues to flow into bowl and overflows on to the floor
If it overflows while not in use it will be the water valve. If it overflows while in use it could be the water valve or pressure switch or pressure hose kinked or cloged or pressure chamber cloged need model number for more info
Sep 29, 2010 | Washing Machines
Sometimes washer keeps running water & doesnt fill up. i have to unplug it for a few hours so it can work again...has happened on all cycles...what causes tub not to fill with water
water is siphoning out the drain hose ,drain pipe not high enough "must be 36 inchs"from floor or hose is inserted in pipe to far creating a suction situation ~once over the edge it cant stop...., may need a anti siphon kit on drain hose .
Apr 27, 2010 | Roper RAX4233PQ Top Load Washer
Unit is filling up half way or so and just keeps running, but will not fill up all the way almost like water is draining and running at same time
Tub keeps filling does not overflow.
Solution:
Drain hose must be 36 inchs above floor level to prevent siphoning.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 26, 2009 | Roper RAS8445KQ Top Load Washer
Error codes
F27 = OVERFLOW CONDITION
Did you inspect the filter for clogs I have seen this happen many times The filter is located behind front lower panel and can be white in color follow the hoses its before the pump. I have seen the filter clogged and give these type of symptoms
but here is error code F27 out of the maintenance manual
servicing.
Nov 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water overflows...does not shut off when full.
Empty tub of water unplug unit and pull it away from wall about three feet, tip unit back and on right side of drum you will find a hose connected to it remove this hose and inspect it for clog,if no clog is found nipple end on drum is probably clogged"can be cleared with small wire".If this is not cause then presure switch in upper control panel is bad,"note if hose is not connected to drum that is cause".The pressure switch is connected to the hose and the hose can even be damaged with hole in it if this happens hose needs replaced the length of the hose is important to operate properly and should not be altered in any way.
Apr 20, 2009 | Roper RAS6233KQ Top Load Washer
Error F 09
ill include the offical "f 09" straight from the tech sheet, blah blah blah.. what i would look to be an issue ( find it regularly)if you remove the topo of the unit(3 screws across the back) in the back rigth corner youll find the "Pressure switch" sorta a reddish'brown circular box with a black rubber hose coming out the bottom, you can removeth hose and blow through it, id imagine tht half way down youll find a hole where it has rubbed against teh concrete counter weight, this hole in the hose is whats causing your "f09"you can cut the hose and replaceit, usually i fu\ind a small diameter plastic hose and splice it together, till i getthe replacemnt hose.
60 seconds, an Overflow Condition will occur. In an overflow condition,
or kinked.
pressure switch, and Central Control Unit (CCU).
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
161 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
