Question about Car Audio & Video
Trying to find pinouts for my dead Delco 16060670 radio in my 1990 GMC van so that I can replace it
3 Suggested Answers
SOURCE: delco unlock code and procedure
This is the process for the CD deck. I assume it's the same for any 88-90 deck with the DelcoLok system. It may also work with 90+ DelcoLok I units.
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down. (mine were 881)
2. After doing step one and writing down the code, immediately press the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over). (mine were 322)
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if you're
calling for Chevy, Pontiac, Cadillac, etc... When you hear this,
press 1 for chevy, followed by 02107and hit the * key. (i.e. 102107*) He'll ask you for the 6 digit code that you've written down.(mine was 881 322) Enter that and press the * key. He will then give you a code,(mine was 810 891)
4. To unlock the radio:
A. Turn the ignition on.
B. Press "SET" (000 appears on display).
C. Press "SEEK until the first digit of the code appears.
D. Press "TUNE" until the second and third digits
E. Press "AM-FM" (000 appears on display).
F. Press "SEEK" until the fourth digit of the code appears.
G. Press "TUNE" until the fifth and sixth digits of the code appear.
H. Press "AM-FM". Now the radio can be turned on.
see that help you good luck!!!!
Posted on Jul 12, 2008
Here's another variation that worked for me just two days ago... you DO NOT NEED to take it to the dealer and you do NOT need to disconnect the battery, this can all be done with a couple clicks on your radio and call into that phone number.
This was posted previously on another post. ....
Procedure:
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don’t take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are from STEP 05
07. Call 1 800 537 5140
08. Press 1 then #. You’ll hear Invalid Code, try again
09. Press 139010 then #. You will be asked to enter your four or six digit code followed by *
10. Enter the number from STEP 6 then *
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC
Your radio is now un-locked and usable
Posted on Aug 07, 2008
How do i install a Pioneer Inc. - Automatic Transmission Modulator Part Number: 747017
Is it a Truck , or Van ? What size of engine ? And what size is the Transmission ? For a THM 400 transmission, 88 - to 90. Here is some info. This applies to the THM 400 only.
  1. Raise and support the front end on jackstands.
  2. Disconnect the vacuum line at the modulator.
  3. Remove the screw and retaining clamp.
Fig. Fig. 1: Vacuum modulator on the THM400
  1. Remove the modulator. Be careful, some fluid may run out.
To install:
  1. Install the modulator.
  2. Install the vacuum line. Be careful not to kink the vacuum line during installation. Replace any lost fluid.
May 26, 2014 | 1987-1990 GMC R3500 Transmission Vacuum...
90 GMC Ventura transmission problem
The shift linkage may have slipped. The modulator changes the shift point according to engine load versus vehicle speed. It softens the shift points too. The 2-3 shift solenoid in the trans may be bad too.
May 19, 2013 | 1989-1990 GMC C2500 Transmission Vacuum...
I have the code to unlock my delco what number do I put in when I call the number?
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your GMC servicecentre and get them to enter this code for you.
Mar 19, 2012 | Ac Delco AM-FM Radio Cassette
How to change a heater blower on 1997 gmc safari mini van. I have I have never changed a heater blower on a gmc mini van were do i start?
If your talking about the blower motor, its under the hood. If you buy a delco part there will be instructions in the box. There is a plastic/rubber cover over the motor that needs to be cut with a very sharp knife. Anyway buy the delco part and you'll be able to figure it out from there. Good luck.
Jan 20, 2011 | 1997 GMC Safari
I'm trying to fix my Delco stereo on Chevy Malibu '99. When i bought this car the stereo was not even connected. So i connect it and it does not work and does not show anything. Only if i press hr, mn and...
http://electronics.kellysearch.com/profile/doctor+don's/us/tx/huntsville/77320/900324575
Try Doctor Don's. He is an AC Delco expert who can repair a lot of AC Delco radios. He put some new amps into my Radio/CD player for my 1990 Cadillac Deville so it would play in my AC Delco Radio's place. He really knows what he is doing when it comes to radios.
www.doctordons.com is his website.
Good luck on this repair.
Jan 14, 2011 | 2001 Chevrolet Malibu
Changed radio in a 2008 chevy express van,now radio is locked
The codes for the radio are in the back of the owners manual.
Jul 27, 2009 | 2006 Chevrolet Express
Trying to set the clock on Delco Loc II 1990 Lumina
Turn the radio off. Push the set button until the : blinks. Push scan to change the hours and the seek to change the minutes. When complete, push the set button again and your done.
Mar 17, 2009 | 1990 Chevrolet Lumina
2002 gmc sierra radio stop working
call GMC agency they can help you for free
Mar 17, 2009 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
