Question about Stanley Bostitch N80CB Coil Framing Nailer
Does not fire consistently
Sometimes you have to try several times before it will fire
  • 376 Answers
It may be a loose wire in the safty or in the trigger.
Posted on Sep 29, 2009
I have cases that have been fired once. 223 rem. I bought 68gr bullets along with varget powder and cci450 primers. what would be the best gr weight of this powder to make these reloads.
check your reloading bible . search google .com varget powder loading think I used them once for refrence but never load a max load the first time test several lighter ones till the gun shoots consistent groups .
Mar 09, 2015 | Optics
Flash does not fire consistently
Have you tried replacing the bulb at all or check to see if it may be loose or not have a good connection which may cause it to work sometimes but not all of the time
Jun 29, 2008 | Metz Mecablitz 60CT4 TTL Flash
03 vue sometimes wont start. every once in awhile it just turns over but wont fire try it couple times then starts. the problem has got worse to turning it over several times to where its draining the
Several components help a car start: 1) Starter, 2) Battery, 3) Camshaft sensor, 4) Crankshaft sensor, 5) Fuel pump, 6) Coils/Plugs. Start by testing each of those to ensure spark is reaching plugs on a consistent basis. If u can hear fuel pump - and you are sure fuel is in the tank (sometimes the fuel sending unit goes out, making you THINK fuel is there...). Cover each of those, and it should start...if the security system isn't being signaled to stay activated...security can also prevent a start... :-)
Sep 20, 2014 | 2003 Saturn VUE
Lanson smoke alarm
You should buy a new fire alarm. As you mention it also looks annoying to me and think safety first it can confused you if real accident happend.
Mar 14, 2014 | Home
Starting issues with Toyota 4runner 2000
Without seeing the car I won't know this for certain, neither will anyone else here.
Try checking the MAF sensor. If you have a diagnostic tool, check the resistance at low throttle and high throttle. You are looking for a consistant change in resistance over the angle of the throttle. If it doesn't seem consistant, then this might indicate a fault with it.
Nov 03, 2012 | 2000 Toyota 4Runner
I have a 1998 cavalier, we changed the starter twice and the ignition switch as well. The car will crank over three or four times and then the next time it acts like it wants to start it keep cranking even...
Product Safety - Ignition Circuit Thermal Events # 04002 - (02/18/2004)
04002 -- Ignition Circuit Thermal Events
1998 Buck Skylark
1998-2001 Chevrolet Cavalier
1998 Oldsmobile Achieva
1998 Pontiac Grand Am
1998-2001 Pontiac Sunfire
Due to part availability, this recall is being conducted in three phases. Phase 1 will consist of 1998-1999 vehicles, phase 2 will consist of 2000 vehicles; and phase 3 will consist of 2001 vehicles. When sufficient parts are available to notify customers of 2000 and 2001 vehicles, you will be notified and will receive a new initiation report.
Recall - Ignition Circuit DefectCondition
General Motors has decided that a defect which relates to motor vehicle safety exists in certain 1998 model year Buick Skylark; 1998-2001 model year Chevrolet Cavalier; 1998 model year Oldsmobile Achieva; 1998 model year Pontiac Grand Am; and 1998-2001 model year Pontiac Sunfire vehicles. If the engine fails to start and the driver holds the key in the "start" position for an extended period, high current flows through the ignition switch, and sometimes produces enough heat to melt internal switch parts. If the switch is damaged, a fire could occur in the steering column, even with the engine off and the key removed. The fire could spread to the interior of the car, which could injure occupants of the car or cause damage to adjoining structures.
Correction
Aug 29, 2011 | 1998 Chevrolet Cavalier
94 s10 4x4 4.3 w eng. after sitting awhile sometimes no start
How does it start after sitting for several days? If she fires right-up I'd say the fuel injectors require replacement. Next ime you try to start it and it won't pull several spark plugs. If they appear wet with gas that would be from leaking fuel injectors. When you try to start it you may breath some new air in to the cylinders causing the gas to evaporate off and 30 minutes later she'll fire up for you. If it is caused from leaking injectors (flooding) Try starting it with the accelerator to to the floor and hold it to the floor. Try starting it for 3-5 seconds and the wait 10-15 seconds but keep your foot to the floor (doing this at start-up fuel flow to the injectors) try this several times. Caution though: As it begins to start remove your foot fom the accelerator to avoid over rev-ing the engine. If this is the cause replace your injectors.
I hope this may have helped,
Tom
Sep 07, 2009 | 1994 Chevrolet S-10
Replaced radiator on bmw z3 roadster,
sounds like air or a bad radiator cap, thermostat
Aug 07, 2009 | 2001 BMW Z3
As you pull the trigger slowly the tool cycles several times
It sounds like you have a contact trip trigger that you are trying to operate as a sequential trip. Sequential trip is when you have to put the tool against the work and pull the trigger every time, contact trip is when you pull the trigger and tap the nailer on the work and it fires. If you operate a contact trip like a sequential it will fire but it usually fire more than one nail. Your instruction manual will explain this, sometimes they give you two seperate triggers for the two modes or there is an adjustment on the nailer.
Aug 03, 2009 | Stanley Air Tools & Compressors
Stanley Bostitch N80CB Coil Framing Nailer Logo
108 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
