Question about Xerox WorkCentre 220 All-In-One Laser Printer
Scanner Locked i've installed the software accordingly but facing a problem of printing, photocoping, faxing and scanning. The screen at copier/printer appeared a word scanner locked an dasking for unlocked. Pls advice to solve this probelm. Thank you. Khin Lee
I have the same problem i unpulged and nothing :S
Posted on Sep 01, 2008
  • 208 Answers
  1. Power OFF the printer using the power switch on the rear, right side of the printer.
  2. Wait 10 seconds, and then power ON
Posted on Dec 19, 2007
  • Rick Kasper Dec 19, 2007
    I have looked and there is no scanner latch on that machine, If it is less then one year old you do have in house warranty repair on that.
How can I scan my documents?
It depends a bit on the OS and software you have installed and the connection. First, do you have the full software installed, if available for your OS? If you installed a generic OS driver, you should uninstall it and unplug the data cable until after the full software install requests it. Get the software here: and select your OS. (Newer Windows versions (like Win7) only use the driver in the OS; plug in the USB cable and let Windows Update find the driver.)
Put the document face down on the glass of the scanner or face up in an Automatic Document Feeder (ADF). Make sure the transport lock is unlocked on scanners with that feature.
If you have the full software installed, then start scans, at first, by launching the software (Start > All Programs > HP > HP Director or double-clicking the icon on the desktop). Then set the scan settings (Settings > Scan Settings and Preferences) - this is where you set the default destination and resolution, among other settings. You will see one setting for Button Settings. Once the button settings are set, if the monitor program is running, you will be able to launch scans from the buttons on the all-in-one. Click on Scan Picture or Scan Document depending on the item to be scanned. Adjust any settings and then press Scan. Check the preview if it comes up and then click Accept.
If the full software is not installed or you do not wish to use that software, you can use programs that are already in Windows or a third-party software. Windows XP, Vista and Win7 all include Paint, Start > All Programs > Accessories > Paint, which can acquire scans. Select File > Import from Camera or Scanner > Import from Scanner and then you will be able to scan. Vista and Win7 also include Windows Fax and Scan (Start > All Programs > Windows Fax and Scan). Click New Scan. The Windows Photo Gallery was preinstalled on Vista and is available as a download for Win 7 and can also acquire scans.
If you have problems scanning, try a new USB cable or a different port. If you are using a USB hub or print server, use a direct connection. (Print servers usually don't work for scanners). Scanners require bi-directional communication with the scanner and can fail even if the printer works.
I hope this helps.
Oct 22, 2010 | HP PSC 950 All-In-One InkJet Printer
Which device do you have? If it is an all-in-one that does not have an automatic document feeder (ADF), you lift up the scanner cover and place your photo face down on the glass. If there is an ADF, place the document face up in the feeder. (Using the ADF is not recommended for pictures.)
If it is a stand-alone scanner, the cover is more obvious. For single-sheet scanners, check the manual for which side of the document needs to be forward.
Depending on the OS and software installed, you launch your scan program and adjust the resolution and destination and press scan. (If you have an all-in-one, you may need to install the manufacturer's full-featured software first. Otherwise you will only get printing enabled.) If you use a generic OS driver, the buttons on the unit will not trigger the computer responding to the commands.
Set the destinations for scanner buttons in the software before using the unit buttons when using the full-featured software. Check the manual for specific information. The button presses are noticed by a monitoring program. If that isn't running the unit buttons will not work.
I hope this helps.
(Windows XP, Vista and Win7 all accept scans in Paint (File > Import from Camera or Scanner > New Scan). Vista and Win7 also have Windows Fax and Scan that can acquire scans.)
Sep 14, 2010 | Office Equipment & Supplies
I have an hp psc 1210, I have managed to figure out how to print from my comp, but how do I scan things to my computer
Scanning depends on a few things (OS, drivers). Did you install the full-featured software or the generic driver from the OS? (See the HP support site: for drivers/software.) If you have installed the generic driver and a full software package is available, uninstall the driver, unplug the all-in-one from the computer and install the full software. Then reconnect the data cable.
Place the document to be scanned face down on the glass. (Document feeders need the document face up with the top edge entering the feed first.)
Depending on the setup, you can launch the software from your computer. Double-click on the icon on the desktop or (in Windows) Start > All Programs > HP folder and then click on the HP Director. (Once this software is set up for the scan destinations, if the monitor program is running, you'll be able to press the scanner button on the all-in-one to launch the scan. This is under Settings) Once the program is running, click Scan Picture or Scan Document depending on the item to be scanned. Adjust resolution and other settings as needed - try the default first. Click Scan. If doing a preview scan then click Accept when satisfied with the settings.
If you do not have the full software available for your OS or simply do not want to use that software, you have some alternatives. Windows XP, Vista and 7 all can acquire scans in Paint. (Open the program, then File > From Scanner or Camera) Some versions of Vista and Win7 included Windows Fax and Scan which also acquires the scans (just click New scan). Vista has another program that can acquire scans (Photo Gallery IIRC). Macs may have similar software available. In both cases, third-party software is also available.
If your computer doesn't see the scanner, check the cables. Scanners require bi-directional communication with the computer so a cable that allows printing can be a problem with the scanner. Try a new cable or plugging in to a different port. If you have a USB hub or print server, try a direct connection.
I hope this helps.
May 31, 2010 | HP PSC 1210 All-In-One InkJet Printer
I have installed scanner and disc but cannot find how to use it.I found the test box and that works but now how do I scan?thanks
Canon and other Scanners have both hardware and software buttons to scan documents and photographs.
Scanning with a computer is done with a destination in mind. So the buttons and the software are associated with destinations.
Typical destinations are File, email, Application, and print.
In a simple scan process for copy or print, the item is placed face down on the scanner, then the print button is pressed on the front of the scanner.
The software for the scanner pops up on the screen and the scanner moves the imaging light across the scanner under the glass, reading the item on the scanner. The software sends the image to the default printer and it prints a copy.
You will need to setup your preferences in the software so that a photograph is scanned properly and a newspaper article is scanned to come out clear black and white.
Documents are best saved as PDF files and photographs as TIFF files.
The software will have an expert mode where you can change all the settings and a beginner mode where you let the software decide.
Canon has a great document for your scanner. If it is not on the disk, here is the link. It is called CanoScan 4200F Scanning Guide. I think it will help you to use the scanner for any task.
Apr 24, 2010 | Canon CanoScan 4200F Flatbed Scanner
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Wont scan to computer
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Dec 02, 2009 | Brother MFC-465CN InkJet Printer
I hit scan on my machine and there is nothinbg responding on the computer screen. I am able to copy, print and fax. Help.
Your scanner is not properly installed. It is a separate part of the program. If you have (start - programs) the scanner as a program, bundled with your other printer proograms on screen, double (left) click on the scanner program, it should lead you to the install wizard. simply install the program. If not, try reinstalling your (use control panel - add/remove - uninstall all printer programs FIRST). Look at your software and make sure that the scanner software IS included.
Sep 01, 2009 | Brother MFC 210C All-In-One InkJet Printer
Canon MF 5630 When Photocoping saying please wait
I t sounds like the scanner bulb is never warming up.
I don't think you can buy replacements parts.
Nov 19, 2008 | Canon FAX-JX200
I would like to use my epson stylus cx7800 to receive and send fax's. Can this be done. Please explain and instruct. Thanks.
If you are running Windows, and have a modem, you can use the Windows Fax Services which are built in.
You may not have it installed, as it's an optional component. Go to Control Pane/Add Remove programs. Select Windows Components on the left hand side. If Fax services is not checked, do so, and press OK. You may need your original Windows install CD to complete the task.
If you still need help with this, please respond to this message. If I have solved your problem, I would appreciate you rating this as "solved".
Good Luck
Jul 21, 2008 | Computers & Internet
Xerox WorkCentre 220 All-In-One Laser Printer Logo
275 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
