Home | Dell | Dimension 8100 PC Desktop | Dell Dimension 8100. No ...
Dell Dimension 8100 PC Desktop
Problem for Dell Dimension 8100 PC Desktop
Dell Dimension 8100. No start!
By mkebikecop on Sep 29, 2009
I have an dimension 8100. When I push start a yellow light comes on on the mother board, the cooling fan turns, and a series of five beeps followed by two beeps then two beeps and finally one beep. That is where it ends. Never starts.
Best Solution
posted on Sep 30, 2009
Very Helpful)
Gort007
Rank: Guru  Dell Computer Hardware  Expert
Rating: 89%, 461 votes
The exact beep code for that machine means that you are using unsupported RAM.
This Dell computer uses RAMBUS memory (aka RDRAM / RIMM)... not DDR or DDR2 /DIMM
Try this:
Use only one memory module (the oldest one if you added any).
It will work with no problems.
ok, replace that module with the largest capacity (1GB??) or with the newest module. May not work consistently...
Check with Dell website to determine what brand RAM is supported on that machine.
or purchase RAM directly from Dell.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 29, 2009
Not Rated)
hacks14
Rank: Master  Computer Hardware  Expert
Rating: 100%, 1 votes
ok i know this 80 % either you have no ram in the system or the ram is faulty and or not placed correctly
Was this helpful?
Yes
No
Solution #3
Not Rated)
parrotheadpc
Rating: 89%, 537 votes
Look on the back of the case where the devices plug into it. There will be a set of 4 led lights. starting from the top down oe left to right depending on how they are situated, look at the lights and this is a doagostic of what is happening during the boot sequence. These are green and yellow lights and their order and color are the signifigance of what is wrong, if you have your manual, the meaning of the colors is in there under troubleshooting. I'll see if I can find it......check this out
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm
Was this helpful?
Yes
No
Solution #4
Not Rated)
bob_computer
Rating: 87%, 1191 votes
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Was this helpful?
Yes
No
Solution #5
Not Rated)
ag66339
Rank: Wiz  Computer Hardware  Expert
Rating: 84%, 42 votes
You probably need a new motherboard as this can mean that your CPU is fried or just the motherboard is shot (5 beeps). I would try removing the RAM from the motherboard and re-seating it.
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 8100 PC Desktop
Questions and Unsolved Problems for Dell Dimension 8100 PC Desktop
Do you recommend Dell Dimension 8100 PC Desktop?
Answer
Answer
I want to clean the inside of a sony v3s but I cant figure out how to get in. Can you help?
Answer
I cant get my Toshiba Equium to work off the mains. I have had it on charge over night to try and... (More)
Answer
how do you know if you get fcpga or fcpga 2 on the motherboard? it is socket 370 and fc pga 2 is... (More)
Answer
Cant find short cut for games on Pc Advisor
Answer
my computer just keeps clicking at the multi socket will not make a starting connection
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 8100 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
