Question about Maytag Performa PAV2200
Warm water filling up washer, with no hot water hooked up to wash
When my washer is set on cold/cold cycle, the water that that fills up the washtub starts out as cold and then turns to a very mild lukewarm water. I thought I had a leaky hot water faucet and disconnected it from the washer. With no hot water supply hooked up, I am still getting warm water. Why? Does the washer have a thermostat to control the tempature of the water regardless of the supply?
    President:
  • 1,304 Answers
Exactly
it will maintain 60 degrees but cycling hot cold
thermistor
Posted on Oct 05, 2009
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
Hot/cold cycle stops before filling up
Your washer has a set amount of time to fill. If the flow is low and the time runs out, then all you will get is the amount of water that was able to fill. Check your lines to be sure that they all fully opened.
Aug 12, 2012 | Admiral 32 cu. ft. Washer
Front load kenmore washer will not fill on rinse cycle
yes you should have both hot and cold hooked up. if that is not possible splice the line you have and y it into both inlets. thats not the best way to do it but will solve the imediate problem.
Jan 24, 2010 | Kenmore Elite 45986 Front Load Washer
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Washer will not fill up with hot or warm settings, only cold.
kenmore washer hot or cold fills ok but will not fill with warm but only cold water
Mar 15, 2009 | Kenmore Washing Machines
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
Mar 03, 2009 | Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
139 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
