Question about Western Digital (WD3200JS) 320 GB Hard Drive
WD3200JS Electrical failure? No spinning, overheating of board
WD3200JS-22PDB0, Nov. 2006
Used as an external hard-drive for a laptop, with an Icybox S-ATA case.
I've got what seems an electrical failure: no noise whatsoever on power-on.
Leaving the power on for some time causes overheating of the part of the electronic board near to the central motor.
Shall I try a substitution of the PCB?
The drive is a data-only drive, no operating system installed.
Thanks, Indro.
    Champion:
  • 331 Answers
I would not swap the PCB on this drive without checking the insultation. Heat damage may effect the U12 chip; or smooth chip. However, a bad pre-amp (very common on this model) will toast many chips. Replacement of the pcb may end up for not if the pre amp toasts the next pcb.
In my experience, I replaced the pre-amp (headswap) and pcb; and was able to recover everything necessary. http://techrxgb.com Also, the 22pdb0 has a weird ROM ata for the motor; and it's really touchy about working.
Posted on Jul 22, 2010
  • 696 Answers
Hi Indro,
HEat issues like that can be caused either by a failure on the PCB or internally. Remove the PCB board and inspect it, if it's an issue I have seen occasionally you will have a hard time removing the PCB as it will have blown out a chip near the contact point for the drive and will be somewhat fused to the padding between the PCB and the drive chassis.
If this is the case a new board runs about 50% chance of fixing the issue, try finding one on eBay and replacing it. If that fails or if there's no noticable failure on the PCB, chances are the failure is internal and you will need the help of a professional facility with a clean room to get your files back. If this is the case and you don't mind spending a few bucks for the file, respond with your location(Country, State and City) and I will refer you to a nearby facility that has the appropriate equipment to assist you.
Hope this helps FixYa,
Chris
Posted on Sep 30, 2009
BIOS signals hardware failure
could be a bad lead or connection
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Apr 13, 2012 | ASUS Computers & Internet
Can I use my current w d. external hard drive with my laptop computer as well as my desk top.
you can only use it as an external on the laptop if you use it as an external you can use on the desktop just plugging the usb also if your motherboard has sata conection you could install it into your desk top.
Oct 06, 2010 | Western Digital (WD3200JS) 320 GB Hard...
The power light on my external hard drive just keeps blinking green and the hard drive will not turn on. Any ideas?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
replace them they are probably old and faulty ?
good luck
Sep 07, 2010 | Western Digital (WD3200JS) 320 GB Hard...
Computer identifies attached drive but does not locate it in computer file folders
western digital (wd3200js)320gb have failed in receiver taken out and run in 3.5 external enclosure using proper connecting cables but my computer is not recognizing there is a hard drive connected. I am using pvr explorer what to do for data recovery.
Sep 24, 2009 | Western Digital (WD3200JS) 320 GB Hard...
WD1600BMVS (my passport external hard drive serial ata)
Also my Hard drive which should be 320gb is only showing as 298. Where did my other 20gb go?
bhavesh
Jun 07, 2009 | Western Digital (WD3200JS) 320 GB Hard...
WD ITB harddrive makes noise
From what you've described, it sounds like you have an external drive, rather than an internal. A clicking noise generally emplies hard drive failure, but sometimes the problem could be the actual USB cable. Have that switched and if the problem persists, try running WD's diagnostic software for any fatality. This will only work if the drive is visible in disk management (not necessarily my computer).
Apr 09, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Ibm t43, xp pro won't recognize my WD my book
please write down the error and contact me now
anaesarora online
Feb 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
External Hard Drive Installation
MAKE IT A MASTER FIRST ..IF NOT THEN MAKE IT A SLAVE.
IF ITS A SATA THE PCB HAS A JUMPER SETTING TO SET IT SLAVE ..MAKE IT A SLAVE FIRST IF ITS SATA
Jul 22, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Maxtor 120GB Hard Drive
Is that external???
Mar 24, 2008 | Maxtor Hard Drive
Western Digital (WD3200JS) 320 GB Hard Drive Logo
693 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
