Question about Biostar K8M800-M7A Motherboard
Bios rom error - Biostar K8M800-M7A Motherboard
    Problem Solver:
  • 4 Answers
Well, if you can "flash it", you may use an integrated software, who loads the normal BIOS ROM/FLASH from a USB storage (MAximun a 2Gb FAT32 Pendrive), this will depend from the manufacturer. If it is an OLD motherboard, you may go to technotrash shops, buy and crappy old pc, take it BIOS ROMchip and put on the place of you bios chip, but must be the same model, and if you install wrong, something very bad will happen. You must search on the manufacturator's database and the bios creator's database, to find the right way to reprogram or replace it. Remember: on very old Pcs, the BUIOS chip is removible, the most recent PCs, uses flash memories, who can be erased easyly by help of manufacturator software, and reprogramed.
Posted on Sep 29, 2009
Gigabyte bios rom error beep code
http://www.gigabyte.com/products/product-page.aspx?pid=3013#dl new bio here
Dec 03, 2013 | Gigabyte GA-EP45-UD3R Motherboard
Bad Locksum BIOS CD_Rom not found when I try to
it's not locksum ,its Check SUM or CRC errors.
what OP, are you running,? windows what. i guess.
the CMOS battery just died.
install a new one.
all puters this old do that, the battery is good for 7-10 years,
and all fail.
DO NOT FLASH your BIOS, fix the real problem first
when the battery dies, all our bios setting were lost
including boot device, and order
fix battery
then go into BIOS and put back boot order.
Mar 22, 2017 | HP Pavilion a815n (PS512AA) PC Desktop
BIOS ROM checksum error
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
When i'm turn on my pc this message would appear ''bios rom chesum error'' what should i'l do?
the ram has some error
better remove the rom blow air to it wipe it wit a clean soft  material
then replace the same
Mar 06, 2009 | Computers & Internet
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Bios check sum error
You can try flashing/updating the BIOS if nothing works.
Nov 28, 2008 | Computers & Internet
Bios ROM checksum error
The rom you used to flash the bios may not have been the correct one for your mobo, or it did not complete the flash entirely. Try using the usb a drive to flash it again and/or revert back to an older version.
Aug 01, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
Rom bios error
turn off your comp.,go to cmos setup,go to boot option,make your cdrom as the first boot device.insert the support cf of your mboard to cdrom to recover the original rom bios because your bios file was corrupted already.dont turn off your comp, while flashing.
May 19, 2008 | EPoX EP-4PEA+ Motherboard
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Biostar K8M800-M7A Motherboard Logo
101 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
