Question about Garland H283 Gas Kitchen Range
Garland stove pilot light problem, again but different
Again, our 50 or so yr old Garland commercial (six burner, double oven, salamander) is having pilot issues. You all helped us clean up the one oven pilot with the needle and seems to be working fine. But, we turned off the pilot to the second oven 3 yrs ago when we rented the house. Now that we are back we are trying to re-light it and it won't take. We did the cleaning with the needle but still it will not light. Any ideas?
  • 15 Answers
I'm not familiar with Garlands. When I run into a similar problem with other stoves of that vintage (Wedgewoods, etc.) I trace the pilot lines piece by piece, from the manifold to the pilot burner, if necessary opening a connection or two to see where I'm getting gas and where I'm not.
Is there a needle valve for adjusting the pilot flame? Is there gas getting all the way to the pilot burner? When it's the pilot burner itself that's the problem, I take it apart, brush/blow/shake out the crud, and run a small drill (#79 or so) through the orifice.
Posted on Dec 19, 2007
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
I have a commercial garland air deck gas oven model G56PB its not staying heated to the set temp. it will heat up to the set temp. then five minutes later the tempreture will drop and will not heat up to...
I have seen Garland's have issues with the pilot light. see if you can watch the cycle.It may takes several minutes. I have seen where the pilot actually lifts off the pilot assembly and go out and cause oven to fail. Turning off and on resets the failure and sometimes it will light. Start there and be patient.
May 11, 2017 | Garland Ovens
Pilot relighting Garland Commercial range
The main burner valve is the oven valve. The pilot will be next to the burner and you either have to insert a long shiskabob stick ( lit) into the hole or lift up on the bottom of the oven (inside) and you will see the pilot.
Feb 09, 2010 | Garland H286 Gas Kitchen Range
I have a Garland stove series #G286, the oven won't stay lit.
it sounds like a venting problem, the oven heats up and it not venting,it will put the pilot out.
Aug 27, 2009 | Garland H286 Gas Kitchen Range
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Dec 16, 2007 | Garland H283 Gas Kitchen Range
60" double oven gas Garland stove
We use a Garland from the 1960's and pilot lights ARE scary and should make you nervous. This is why they are no longer allowed in new gas ranges. I mounted an inline gas shut off to the stove where the gas enters (on mine this is right in front on the left side). It turns on and off like a burner and when we are done cooking we simply shut off the gas there. To light the burners or the stove I use one of those long reach lighters. I go to bed knowing that NO gas is coming in.
We love the stove, it makes cooking more fun.
Good Luck!
Oct 24, 2007 | Garland H283 Gas Kitchen Range
Oven pilot light won't light
It is usually a bad thermocouple. Mine had only had a weak pilot flame and the problem turned out to be a corroded and leaking pilot gas line. It was leaking whee it enters at the bottom of the oven chamber.
Mar 05, 2007 | Garland H286 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
1,001 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
