Question about Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close
How do you replace the seat? - Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close
  • 38 Answers
To replace seat. look rite at where the lid hinges there is like two block abour 6 to 8" apart. take a small screw driver and pop free the lil door covering the srew head. take a big philps or straight head screw driver. and then look under neath where bolt would stick out below. and you will see a nut,you should be able to hold nut by hand as you titen the bolt. both nut and bolt are plastic. draw good and snug. hope this helps. duane.
Posted on Oct 04, 2009
How to replacing valve seat
For a standard seat replacement you will need to shut off water and remove stem. Below the stem is the seat. It will either have a square center hole or hexagonal hole. If you don't have a seat wrench, you can get one at the hardware store when you pick up your replacement seats and washers. The new seats might not have the same inside type hole, so buying a tool that has both styles would be helpfull. Insert the correct seat tool into the seat and turn counter clockwise to remove seat. Reverse this to install new seat. Be sure to put a small amount of of pipe joint compound on the seat threads before installing. Replace the stem washers and reinstall on faucet. Make sure you take off the aerator or shower head and flush debris from system when you turn on the water. If your valve is a wall mount faucet with horizontal stems, you will need to take the faucet off at the union nuts and replace the seats from the back side of valve body. Remember, Lefty Loosy and Righty Tighty.
Hope this helps and good luck.
Sep 09, 2014 | Price Pfister Plumbing
Can I replace my 98 grand prix driver's seat with
You can replace it as long as the one you are replacing is the same set-up. If you have a manual adjusting seat and replace it with a power seat it will fit but you wont have the hook ups for it. Also make sure if it is a bucket seat (single person) you dont replace it with a bench (3 persons fit in front) seat or you will run into problems with the center console and shifter. vice versa may bolt up but there will be a gap between the 2 front seats
Nov 22, 2011 | 1998 Pontiac Grand Prix
WHERE CAN I GET REPLACEMENT SEAT AND COVER BUMPERS FOR MY BEMIS TOILET SEAT?
If the seat is a molded wood seat, you can usually get bumpers by contacting Bemis Customer Service, 920-467-4621. The bumpers on plastic seats are not replaceable because they are part of the seat.
Mar 26, 2011 | Bemis CHURCH Elongated White Slow Close...
Eddie Bauer car seat seat belt replacements??
Hi, car seat belt replacements can be found at amazon, click here and take a look: High Impact Reduces Brake Dust Made in USA. Wish you best of luck. Cheers
Feb 25, 2010 | Eddie Bauer 3-In-1 with Latch
Gas leaking into crankcase in Briggs Stratton 17 1/2 hp engine-
Hi
If it has a steel seat i would not bother with the seat if it has a rubber seat i would replace. To install rubber seat you just need a punch or anything that fits in the hole with a flat bottom.
Sam
Jan 07, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
BOUGHT NEW SEATS TO REPLACE BURNHOLE SEATS CAN I JUST DISCONNECT BATTERY THEN REPLACE THEN RECONNECT BATTERY? ALL OKJ AFTER THAT OPR NOT?
seats has nothing to do with airbag. replace the seat and make sure all wires if there are any, are reconnected, and sure the seat belt sensor are not touched. and the seat sensor are conncted back.
Jun 01, 2009 | 2007 Nissan Versa 1.8 Sl Hatchback
My seat frame is broken. I want to buy a used seat and replace it totally. How do I remove the old drivers seat and replace it with a new one? It is a manual seat.
You will have to unbolt the seat from the undercarraige of the truck. If you look under the vehicle in the proximity of the seat you will see the nuts to remove.
May 29, 2009 | 1999 Ford Explorer
Replace original seat cover
I didn't have to take out the seat to replace the bottom seat cover. It was tight working between the seat and the console, but I did it.
Aug 02, 2008 | 2008 Toyota Camry
Kohler K-3384-2 San Raphael Elongated Toilet With French Curve Quiet-Close Logo
215 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
