Question about Marshall Music
JCM 2000 TSL 601 MARSHALL AMP TURNS ON NO SOUND TUBES DONT LIGHT
I HAVE A JCM 2000 TSL 601 MARSHALL AMP THAT I BOUGHT IN 2001. I ONLY PLAYED THE AMP MABE 15 TIMES AND THEN PUT IT UP FOR STORAGE IN A HARD FIBER GLASS AMP CASE. MY FREIND WANTED TO BUY IT SO I WENT TO SELL IT TO HIM AND IT WOULD NOT WORK. WHEN YOU PLUG IT IN THE TO THE WALL THE POWER BUTTON LIGHTS UP. SO I WILL LET I SET IN STAND BY TO LET THE TUBES WARM UP THEN I TAKE IT OUT OF STAND BY AND THERE IS NO SOUND. SO I TOOK THE BACK OFF OF THE AMP AND I NOTICED THAT THE TUBES ARE NOT LIGHTING UP. I HAVE A VOLT OMS METER AND WOULD LIKE TO TROUBLE SHOOT IF ANYONE HAS ANY INSTRUCTIONS FOR ME.
  • 1 more comment
  • Paul M Tringuk Jr. Apr 24, 2012
    A common problem with these amps is a failure of the BR1 bridge rectifier that feeds the heater voltage to the preamp tubes. This repair should be done by a professional as there are hazardous voltages inside the amp chassis. After the repair is completed add a muffin fan to keep things cooler.
    A common problem with these amps is the failure of BR1 bridge rectifier that feeds voltage to the preamp tube heater circuit. This repair should only be done by a professional as there are hazardous voltages present inside the amp chassis. After completing the repair you should add a muffin fan to keep the amp cooler and increase reliability
  • Anonymous Mar 27, 2014
    my marshall tsl 2000 jcm head reverb is not working is it the valves
    Problem Solver:
  • 7 Answers
Had a repair this week, same symptoms... The solder on the AC power plug was broken. Just that.
Sometimes it´s simple.
Posted on Feb 14, 2015
  • Paul M Tringuk Jr. Feb 14, 2015
    If the amp powers up,but, the tubes don't light like in s_r_romeros Post, it's NOT the AC power plug, but will more than likely be the rectifier.
    Sergeant:
  • 336 Answers
If the amp comes on, the fuse is ok. I would agree with Paul about the br1 rectifier. It is quite common.
Posted on Mar 08, 2013
A common problem with these amps is a failure of the BR1 bridge rectifier that feeds the heater voltage to the power and preamp tubes. This repair should be done by a professional as there are hazardous voltages inside the amp chassis. After the repair is completed add a muffin fan to keep things cooler.
Posted on Apr 24, 2012
    Could be as simple as a broken wire on one of the reverb tank transformer wire
  • Marshall Master
  • 5,603 Answers
If the tubes are not lighting, either the fuse has blown or the power transformer might have an issue.
Be vvery careful as there are lethal voltages present in these.
If the fuse blew, replace it and try just once as there could be other problems and more damage could be done.
Posted on Sep 30, 2009
Hi I have A Marshall JCM 2000 TSL122. It starts out having full sound then all of a sudden no sound then after a few seconds, minutes or several minutes sound is back!
I suspect it's your input jack if it stops working immediately and comes back immediatly rather than fading in and out. Give it and any other jacks a good cleaning and see if it helps.
Jul 27, 2015 | Marshall Music
Marshall jcm2000 tsl combo turns on but no sound from any channel
Make sure speaker cable works and is connected then check fuses. If it has a master volume, make sure it's turned up.
Sep 04, 2014 | Marshall Amplification Music
After a gig last night we tried our Marshall JCM 2000 DSL401and it had developed two noises without anything plugged in. The first is a transformer hum that I'd never noticed before and when standby is...
Likely the filter capacitors have a problem. Best to take this in for repair... it is ODD that there is noise with the standby switch is in standby... That makes no sense... In standby it appears that power is removed from the power amp high voltage so nothing should come through the speaker... Unles maybe one off the power tubes had a total meltdown which should have blown the fuse.
Sep 10, 2011 | Marshall Amplification Marshall Cover For...
On the Marshall 5 button footswitch for the TSL, there are 7 wires in the cable, 6 of which are clearly labeled by color on the circuit board in the footswitch. The brown must be combined with another wire...
Only 6 wires are used by the amp. Tie the brown wire to the metal frame to act as shielding if anything. You will probably find that the brown wire either connects to the shell of the connector or to nothing.
Apr 23, 2011 | Marshall Amplification Marshall 5-Button...
My jcm 2000 tsl 100 , doesn't produce the amount of gain i expect from it, i thought it gave as much as a mesa rectifier amp, i replaced the preamp tubes , but still, not enough gain
The sound level output is a true measure and unless you can compare specifications between units, you are probably listening to salesmen who want to sell you product.
The power level rating is OFTEN falsified and a LOT of the actual sound level performance depends upon the speaker used.
You should get a sound level meter to compare amps.
Remember to NEVER run more than 100 Db to avoid legal liability for hearing damage. I know several musicians who are nearly deaf now from being exposed to high levels too long. You can look up what the govt limits are now with Google.
The 2000 should EASILY reach the 100 Db level.
Mar 13, 2011 | Music
I have a marshall JCM 900 when I plug in my foot switch and try to play it pops and cracks .I know it's not the foot switch or my guitar.I checked the tubes they look alright so what part is broke in my...
I doubt that you have checked the tubes... tube checker's are rarity now and you can't look at a tube and "tell it is alright". If you leave the footswitch out does it do the same thing?
The probllem could be many things...and you haven't mentioned how you tested the items you are exhonorating. A common problem is a noisy or broken INPUT jack. Musicians forget to loop the guitar cord through the handle and the cord gets moved and yanked sideways wearing the jack and often breaking internal parts. Yjos also goes for the cord to the footswitch as well. Cords and connectors/jacks are the common problems. Less common but frequent are damaged volume control pots due to damage when handling... including broken solder where these attach to the circuit boards.
Feb 11, 2011 | Marshall Amplification Marshall JCM800...
I have a Marshall TSL 601. I recently re-tubed my the amp with new Tung Sol tubes and biased per factory specs. With the new tubes installed in both the preamp (12AX7/ECC83's in V1, V2, V3, and V4) and...
First thing is that if you bought MATCHED pairs of the EL34's a COMMON mistake is to install the pairs wrong. Correctely install a pair as the OUTSIDE tubes of the line and then the remaining pair as the middle two tubes of the line of tubes before biasing.
Funny thing, I just ran across this problem you have with a Bedrock brand amp that uses the same configuration as your V3 tube does. This is really a stupid configuration engineering wise as they tie a plate at high voltage to the grid of the second stage in the tube as a cathode follower, This means that the second section has the cathode at a reasonably high voltage relative to the heater with wide audio swings on it as well... Tubes are NOT designed to work that way and result in noisy behavior, One would have to select tubes that have very low heater to cathode leakage in the second section of the tube... What you are seeing is the result of very poor engineering practice. Marshall is probably testing tubes for the leakage and branding them as such...
I think that designers of this circuit have NOT had experience with tubes and have applied transistor type designing to this use... it is plain stupid and myself I would re-engineer the circuit if it was mine or build a tube tester capable of measuring the heater cathode properties to select a suitable tube to use.
Jan 29, 2011 | Music
The valves on my Marshall TSL 122 are getting to hot.What might be the problem? Can you get me the scheme for that amp?
Probably the bias is set wrong... Please note that when installing MATCHED pair tubes, the tube pairs usually go at opposite ends of the strings, that is one on either side of the center of a set of four.
Jul 23, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall JCM 2000 dual super lead 50 watt going out on me
Very nice amp!
First off, is the amp getting sufficient power? An unreliable AC current from your wall can affect the performance.
Have you tried the amp with a different speaker? Checked for a loose connection from the amp to the speaker? Is it the correct ohms rating?
Second, are you experienced in electronics? The problem could lie in a faulty solder connection, a bad component, etc.
If you are not confident in opening the amp and troubleshooting it yourself, take it to a audio repairman. Marshall's are some of the easier ones to fix.....
Nov 22, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Music Logo
1,150 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
