Question about Zebra Printer 140-751-00000
How do you change the font on a Zebra Z6Mplus printer?
  • 257 Answers
It has to be done in your software. You can't change fonts in the printer settings. The printer doesn't have the ability to make changes like this.
Consider this printer to be just like a laser or inkjet printer. It's just going to print what you tell it to print, how you tell it to print.
Posted on Oct 09, 2009
2 Suggested Answers
  • 257 Answers
SOURCE: i have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Posted on Jul 08, 2009
How to change the font size in ZEBRA 220Xi4
You would change the font size in the label design software that you are using. Click on the text box and then adjust the font and font size.
Jul 08, 2011 | Zebra 220Xi4 Thermal Label Printer
I just bought a used Z4Mplus printer, I need an illustration/drawing to show me how to install the ribbons? Thanks.
Goto http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html and then ctrl+f paste Z4Mplus in the Find: slot.
You will find (Z4Mplus & Z6Mplus Users Guide 13163L-002 Rev A (en)). Next column: 13163L-002 Rev. A, next column: User Guide next column: English last colum: Download. The download is a 171 page manual.
Jun 01, 2011 | Zebra Z4Mplus Label Printer
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Slow printing problem
Take a look at your label design. If you have a lot of text fields using true-type fonts or graphics, this can result in a delay before printing. The font info has to be sent to the printer before printing. If this is the case, change the fonts to an "internal zebra font". These are fonts that reside in the firmware of the printer and result in much faster throughput. The fonts are usually listed in the software and/or printer driver you're using.
Hope that helps !
Apr 21, 2010 | Zebra LP 2844 Thermal Printer
How do i change my printer font
The font size is due to the printing material i mean the doc , pdf files.The printer doesnot have any fonts.You will get the same font of your input.Increase the font in your input material.Automatically you will get bigger fonts
Mar 18, 2010 | Zebra RW 420 Thermal Printer
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
I have a zebra z6mplus the ribbon keeps breaking
Jul 08, 2009 | Zebra Z6M Plus Thermal Label Printer
Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Jun 03, 2009 | Zebra Z4Mplus Label Printer
Zebra TLP 2844 Controlling the font size w/iSeries??
Hi Burgymon,
The font that is used under the barcode will use the last font properties described prior to the barcode in the output. You may want to suppress the human readable option and create a separate text field to display the text version of the barcode contents.
Mar 25, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Need to increase my font on Zebra 105SE
All fonts are controlled by software. You cannot change them throught the front panel.
Steve W
LazerTek, LLC
Jan 18, 2008 | Zebra 105Se Thermal Printer
Zebra Printer 140-751-00000 Logo
256 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
