Question about Motorola HDT101 DTV Receiver
Digital television signals
I need to transfer my digital tv signal from downstairs to my three bedrooms upstairs. What do i need to do this.
  • 38 Answers
What type of digital tv signal? Satellite or OTA (Local Digital Antenna Channels)?
What type of equipment is the split signal going to? Straight to the tv's or some sort of Satellite or HDTV Tuner box?
Posted on Dec 19, 2007
PS3 has lines and buzzing sound when played in an upstairs bedroom. When played in a lower room, it is fine.
this can be due to heating of the unit sir.
please try cooling the unit using external fans
Jul 01, 2008 | Video Game Consoles & Games
Using a video transmitter to extend your cable network to another TV in the...
When I first purchased a cable plan I only had one TV in my house and it seemed like a waste to get multiple cable boxes for TV that I had not yet purchased. When the prices came down on TVs I decided that it was time to get a set to go in my bedroom upstairs but I didn't have a cable box to connect to the set.
I could have gone out and spent a $100+ on a new bulky cable box that is not really all that pretty or I could get a video transmitter that will extend my signal to the upstairs TV set for around $50. Even though it takes a little bit of set up the results are great, I can even use the one remote on both television sets.
To set up your video transmitter first you have to take the transmitter and receivers out of the box and make sure that they are both set to the same channel. This will ensure that they will read each other. Then you take the cables that came with the transmitters and connect them to the back of the cable box, matching up the yellow, red and white cables to each other. Position the transmitter box so that it is lined up with the signal transmitter of the cable box.
Then you want to go upstairs to the second TV and connect the receiver to the back of the television set the same way that you connected the transmitter to the cable box. Take the remote from the set downstairs and it should have extended the connection of the cable box to both TV sets. Now you are able to control the cable box from upstairs and watch your stations on both TVs.
on Jan 22, 2014 | Televison & Video
I have a 52" RCA
Make sure you are connected to correct cable IF connector,Go to Menu and see if you are on Cable or Air.Then Do AutoProgramming.
Feb 17, 2011 | RCA HD61W140 61 in. Rear Projection...
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
We have a tv upstairs and one down stairs, they
Since the antenna is on the roof the signal has further to travel to get to the downstairs antenna and as a result the signal is weaker. Install a device on the antenna line before the first TV called a signal booster. This unit plugs into the wall and gets connected to the antenna wire too. It will improve the signal for both televisions.
Aug 14, 2009 | Televison & Video
Connecting to a lapto
Hi rgf47331,
When you move upstairs there is a solid wall in between that interfears with the signals.The only thing you can try is calling up belikin and asking them to check your settings on the router and see if changing the mode or channel helps. i wont recommend you do that on your own as you may end losing the connection altogether.
I hope this helped
Feb 16, 2009 | Belkin (F5D7230-4) Router (587009)
Can see my network but wont connect
Yes you may trying chaing the channel to 11, because i have hear that chaning the channel will resolve this problem
Oct 23, 2007 | Belkin (F5D9230-4) Wireless Router...
Motorola HDT101 DTV Receiver Logo
606 people viewed this question
Top Motorola Televison & Video Experts
Jaime Hernandez
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
