If this is still under warranty (3 years from date of purchase) you can send your 360 back to Microsoft to be repaired for free. Assuming it is not under warranty, it will cost you around $100 from microsoft to be repaired. Now, you can often find people locally to fix your 360 on Craigslist.com but be weary of who you let fix it.
Inspect and clean your disc Take a close look at the
bottom side of your game, movie, or music disc (the side without a label or
image). Are there scratches? Excessive scratches or smudges can prevent your
console from reading the disc. Clean your disc Hold the disc by
the edges without touching the top or bottom surfaces. Using a soft,
clean, slightly damp cloth, lightly wipe from the center of the disc outward.
· Note Use ONLY water to
clean the disc.
Once the disc is clean, load the disc into your
console and see if the disc plays.
Follow these steps when you are facing "disc wont read" problem
Step 1:Remove the disc from the system.
Step 2:Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application.
Step 3:Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance.
Hi, Follow these steps when you are facing "disc wont read" problem Step 1:Remove the disc from the system. Step 2:Use a cloth to clean in small circles around the disc (not in a big circle going around the disc). Use DVD or CD disc cleaner if available. If you use cleaner, use a different dry cloth to clean the disc no more than three minutes after application. Step 3:Verify that there are no disc-destroying marks on the disc. Deep scratches and chips in the middle of the disc can render a disc inoperable.As your Playstation 3 is used more and more, the lens that reads Blue-ray discs can become dirty. This will lead to discs skipping or not being read by the console. If you find this is happening on your Blue-ray discs, either movies or games, you may need to have your console cleaned. Be careful when attempting any sort of cleaning of your console, as improper handling will further damage the Playstation 3. Contact a member of Playstation Support for information on console maintenance. Thank you !!
Your disc drive will need to be replaced, or you can mod your wii system at www.wiihdmods.com and get 100 wii games playable from a hard drive for 150.00
Your PS2 lens is probably weak or its dirty.You should try to clean your PS2 lens first.A dirt on lens wont let your PS2 lens to read your Game disc. Watch this video this will help you to know how to clean your PS2 Disc Reading Lens.
Try to place your PS2 at clean place and clean your PS2 regularly.
If Wii gives Disc Read Error, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide. , .
