Question about AEG Lavamat W1450 Front Load Washer
Rotation seems locked between cycles clockwise anti clockwise Almost as if the brake is applied?
  • jersey gerry Jan 24, 2008
    • That is what I feared and I have looked to purchase a used machine to have the motor so far unsuccessful thanks I appreciate your comment.
  • 126 Answers
You need a new motor. ;)
Posted on Jan 24, 2008
What is anti-lock braking system on cars?
Anti-Lock Brake systems are all essentially the same they will prevent the driver form applying 100% Brake pressure and locking up the wheels while driving. The ratchet the pressure more slowly to prevent the car from skidding. Our first reaction in an emergency is to slam on the brakes and that is 90% of the time not the right action. So Anti-Lock brakes are designed to prevent this unwanted skid.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_411a7faba7ce8217
Sep 17, 2014 | Isuzu Rodeo Cars & Trucks
Clicking sound when I apply the brakes
if you have anti lock braking that's a norrnall thing to have a small vibration or clicking in the brakes but take it to a shop to be sure
Aug 19, 2014 | 2011 Chevrolet Tahoe
I have a 1999 dodge caravan that as your driving the rpm r high but the brakes seem like they r locking up , could this b the anti lock brake sensor goin bad ?
Check your emergency brake. It's easy to apply it accidentally on this model. I hope you haven't burnt it up already!
Drive safely!
Jul 12, 2014 | 1999 Dodge Grand Caravan
What means ABS
ABS means anti lock braking system and if you have a light on for it, then maybe one of the wheel speed sensors is bad or not sending information to the abs brake module.
Aug 19, 2010 | 1991 Mercedes-Benz 560
The Service traction system, abs and anti lock warning lights keep coming on. I just had 2 oxygen sensors and a wheel hub unit put in. What could be causing this problem?
When the wheel hub was put back in did they omit to connect the wheel speed sensor? The ECU continuously monitors with sensors the speed of the wheel rotation and compares this with the transmission speed. Any disagreement due to wheel spin results in power redistribution to those wheels with traction. If all drive wheels spin and get out of sync with the transmission then the ECU limits the power output from the engine until traction is resumed. Likewise when braking a locked wheel has the brake pressure reduced until minor rotation is again resumed. A missing wheel sensor will cause a failure of both the traction control and the anti-lock braking system
Aug 18, 2010 | 2002 Buick Rendezvous
3 phase air compressor wrong rotation
yes it will you need to make sure you have the proper wires connected to get either clockwise or counter-clockwise rotation.
try changing the hot wires around to correct your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Mar 31, 2010 | Air Tools & Compressors
I have a 2002 Lincoln ls . How do I replace the abs speed sensor? Right front tire?
you have one on the inside of each wheel.
SECTION 206-09A: Anti-Lock Control 2002 Lincoln LS Workshop Manual
REMOVAL AND INSTALLATION Front Wheel Speed Sensor
Material Item Specification RTV Silicone Sealant
FSTZ-19G204-AB (Canada CXC-114A) NAVSTR Sealer
Removal and Installation
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Position the inner splash shield aside.
    1. Remove the pin-type retainers.
  1. Disconnect the anti-lock brake sensor electrical connector.
  1. Remove the anti-lock brake sensor harness from the brake hose clips.
  1. Remove the anti-lock brake sensor.
    1. Remove the anti-lock brake sensor clip.
  1. NOTE: Make sure the anti-lock brake sensor is fully seated before installation of the new clip.
    To install, reverse the removal procedure.
    • Apply a 2.5 mm (0.1 in) bead of silicone sealant to the outside diameter of the anti-lock brake sensor.
Rear Wheel Speed Sensor Removal and Installation
  1. Disconnect the rear anti-lock brake sensor electrical connector.
  1. Remove the rear anti-lock brake sensor harness from the control arm clips.
  1. NOTE: Clean off dirt and foreign material that may have collected around the rear anti-lock brake sensor before removal.
    Remove the rear anti-lock brake sensor.
    1. Remove the anti-lock brake sensor bolt.
  1. To install, reverse the removal procedure.
Feb 24, 2010 | 2001 Lincoln LS
Anti-lock brakes come on when applied under normal conditions
Sounds like a faulty wheel sensor. I would suggest a trip to the repair shop.
May 05, 2009 | 2002 Chevrolet Impala
Anti-lock brake
Hi ,you should check the rear brakes of your vehicle ,it is posible that they are not returning back when the brake is applied,the brake cilinders may be staying open , c1
Dec 31, 2008 | 1994 Isuzu Trooper
AEG Lavamat W1450 Front Load Washer Logo
50 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
