Question about Casio Exilim EX-Z40 Digital Camera
The set-up screen appears every time the camera turns on
When I turn on the camera, the language setup along with the date and time set-up appears. I have to reset it everytime I turn it on. How do I stop that from happening?
  • valle4kat Oct 05, 2009
    What about for a Casio exlim?
SOURCE: Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Posted on Dec 15, 2007
SOURCE: Casio Exilim Z57 Date and Language set up
OK, here's the fix. This camera has internal flash memory that is used to store settings and can be used for limited picture storage. Its use for saving setting is essential, however. If this gets corrupted then the camera won't save settings. Whoever said to format the internal memory had the right idea.
After much experimentation here's how. Remove your SD memory from the camera and turn it on. This will force it to run on the internal memory only. Run through the time/date/location setup again. It will complain about the memory card. Ignore this and press menu. Under Setup, select format. Choose format memory card and do it. This will format the internal memory. Once it is done, turn the camera off and back on. You'll notice that the problem is gone and it has remembered your last setup.
BTW, my camera is a EX-Z75. Not sure there is a Z57 model.
Posted on Apr 09, 2008
mcomijohns
  • 477 Answers
SOURCE: Casio EXZ75 Camera
Your problem does not lye on any memory card. it is because the internal battery that helps the cmos "cameras internal memory" hold its settings has gone out and needs tobe replaced. all you need is 2 1.5 volt hearing aid batteries stacked and taped +-+- and soldiered in place of the old cmos battery. witch is located on the front side bottom close to the bottom left of the lens. and placed next to the speaker. get some small batteries to do this het smaller the better for placement location.Hope this helps I have done this to a few camera's and it works fine.
Posted on Apr 20, 2008
SOURCE: Camera resets when powered off
i have the same problem too, i think i pointed where the cmos battery is but i am not sure if it is the battery or not. when u open the door it should be to the right. it is not accessible til you open the camera. again im not sure if that is the battery. once i comfirmed. ill buy a broken one on ebay and swap it out.
Posted on Jul 24, 2008
bunnydawg
  • 5158 Answers
SOURCE: the date and time start up appears everytime i turn on.
Set the date and time at least once... if it still keeps coming up when you change the batteries the back up battery/capacitor has failed... my old kodak does that so i know the frustration but it's still a good camera
Robert
Posted on Jan 22, 2009
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
Configuring display language, Date and Time Settings.
Perform the reset operation to initialize the camera’s setup (page 136). After that, configure each setting. If the language selection screen does not re-appear when you turn the camera on, it means that the camera’s built-in memory management area has been restored. If the same message appears after you turn power back on, contact your retailer or a CASIO service center.
Main support number800-962-2746
http://www.fixya.com/support/p504372-casio_exilim_ex_z1000_digital_camera/manual-19919
Jan 29, 2008 | Casio EXILIM EX-Z1000 Digital Camera
I have anew z950 did not set date or language corectly and i can't get back to screen to set
Menu; Setup (Logo: Wrench), Language (Logo: ABC), Press OK and you can choose the language you wish.
Menu; Setup (Logo: Wrench), Date (logo clock), Press OK and you can choose the current time and date.
This will also be possible after resetting the cam. Take out the batt for longer than 10 sec after reinserting the batt and switching the cam. on it should give you the option to change the date and time.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Oct 27, 2009 | Kodak EasyShare Z950 Digital Camera
How do i remove the date , time, 101nikon 1939 jpg on top of the
This will always be displayed in your camera. However to choose what will imprint on the pix :
Turn your dial to SETUP and select DATE IMPRINT. Then select OFF (nothing will imprint on pix), or DATE (for just the date to be imprinted), or DATE and TIME (for both time and date to be imprinted)
May 15, 2009 | Nikon Coolpix 4200 Digital Camera
HOW TO SET TIME IN PRINTER
You can set the date and time from the front panel. When a fax is
transmitted, the current date and time are printed along with the fax header.
The date and time format is based upon the language and country setting.
Normally the computer software sets the date and time automatically.
1. Press Setup.
2. Press 3, then press 1. This selects Basic Fax Setup, then selects Date and Time.
3. Enter the month, day, and year (last two digits only) by pressing the appropriate number on the keypad. The underline cursor presented initially beneath the first digit advances automatically to each digit after, each time you press a button. The time prompt automatically appears after you enter the last digit of the date.
4. Enter the hours and minutes. The AM/PM prompt automatically appears after the last digit of the time is entered.
5. Press 1 for AM or 2 for PM.
The new time and date settings appear on the front panel.
Apr 26, 2009 | HP PSC 2210 All-In-One InkJet Printer
The date is displaying on my pictures for our business we do not want this to happen, it just started displaying recently, we have a DC50 zoom camera, top of the line but very outdated
Press Menu, autourg00778004id1973498.jpg to highlight Setup, then OK to access settings Options Return to previous menu.
Camera Sounds
Choose sound effects.
All On (default)
Shutter Only
All Off
Auto Power Off
Choose inactivity time until camera turns off.
10 minutes
5 minutes
3 minutes (default)
1 minute
Date & Time
See Setting the language, date/time.
Date Stamp
Imprint the date on pictures.
Choose a date option, or turn off the feature. (Default is off.)
Video Date Display
Display Date/Time at the start of video playback.
On (default)choose from date formats.
Off
Blur Warning
See Understanding blur warning icons.
On Off
Language
Format
caution.gif CAUTION:
Formatting deletes all pictures/videos, including those that are protected. Removing a card during formatting may damage the card.
spacer.gif Memory Card - deletes everything on the card; formats the card.
Cancel - exits this setting.
Internal Memory - deletes everything in internal memory including email addresses, album names, and favorites; formats the internal memory.
About
View camera information.
Jan 05, 2009 | Kodak Digital Science DC50 Zoom Digital...
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Possible solution?
PROCEDURE
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
2. Write firmware.
Write the firmware.
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Jun 14, 2007 | Casio Exilim EX-Z57 Digital Camera
Why does the date and time setting screen appear when I turn on the camera?
Turning on the camera while the date and time are not set or after the date and time settings have been cleared due to a total cut off of power (which occurs when batteries are dead and the camera is not being supplied power via AC adaptor) causes the date and time setting screen to appear on the monitor screen. When this happens, be sure to set the correct date and time before doing anything else.
Aug 29, 2005 | Casio Exilim EX-P700 Digital Camera
Casio Exilim EX-Z40 Digital Camera Logo
104 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
