Question about Siemens SpeedStream 4200 (13A4200001) Bridge
My fluidmaster 400 is ghost flushing about every ten minutes.
It does not flush but runs for about five seconds then is fine. ideas? It was installed six months ago by a plumber and only started doing this one month ago. It seems very consistent.
    Sergeant:
    Champion:
  • 289 Answers
Okay, WTF does this have to do with this router?
Redo your question!
Posted on Sep 30, 2009
What causes a loud gurgle after flush?
If the flapper does not seat correctly and completely, refill water flows into the bowl and causes a "false flush" and the loud gurgle. You can demonstrate this by holding the flush handle depressed after a normal flush. Also, there may not be sufficient slack in the flapper chain to allow it to seat correctly.
If the flush valves were installed exactly according to the instructions, they should work perfectly and can be excluded as a source of the problem.
Jan 23, 2016 | Home
Why does the toilet make so much noise filling FluidMaster 703A5B
Just replace the flush valve with another one.
Flush the water line by opening valve before attaching new flush valve
Aug 07, 2014 | Fluidmaster 507C White Flush Valve
Have a Duo Flush System from FluidMaster. It continuest to ghost flush. Have adjusted the float valve several times but is still ghost flushes. How can I stop this?
follow this steps and fix it. God bless you
f the toilet bowl overflows, use a plunger or auger to eliminate clogs. If the toilet does not flush, tighten or replace the defective handle , adjust or replace the lift chain , or replace the flush mechanism. Jiggling the handle forces the lift chain or rod to re-seat the flush mechanism, telling you that something is awry.
If the bowl drains sluggishly, remove the clog with a plunger or auger, or raise the water level in the tank .
If water runs continuously through the toilet, lower the water level in the tank , adjust or replace a lift chain or wire , repair or replace a worn flush valve , clean or replace the valve seat assembly .
If water appears under the tank, tighten the tank hold-down bolts , lower the water level in the tank, replace the float valve , replace a malfunctioning ball , or tighten nuts on the water supply line, replace leaking supply line . As a last resort, re-seat the toilet .
If the seat is cracked or unsightly, replace it .
If the bowl or tank is cracked or otherwise unacceptable, replace the entire toilet .
Nov 25, 2013 | Delta Home
Fluidmaster duo flush doesn't flush on setting
What setting.get are you speaking of? If its the water level you can adjust that by the screw on the side of fill valve.
Nov 26, 2012 | Fluidmaster Plumbing
Brand new fluidmaster 400 installed but toilet still leaking
Is The water leaking in or out check the stopper is good and that it is seating right
May 13, 2012 | Fluidmaster Plumbing
When flush my toilet, water keep running until i put my hand inside the middle and pull the float , then stop. toilet make is rapid sl
the ball **** fill valve is a poorly designed valve. replace it with a fluidmaster fill valve and a fluidmaster flapper. flappers do go bad after a year or ten depending on your water quality and choice of flapper but the fluidmaster fill valve will last a long time also. you can also get the water saver fill valve by fluidmaster and there is also a conversion set to change your toilet to a dual flush. all this is at lowes and there is a plumbing pro there to explain further. feel free to give me a positive rating. thanks!
Feb 15, 2011 | Home
We have a Fluidmaster installed within the past 5 years. If the tank is full, it flushes fine but the bulb does not drop down to refill the tank without giving it a ?little push?. There appears to be a...
The chain needs to be attached to the tank lever arm. The idea is that when you depress the handle pulling up on the tank lever it will open the flapper and release the float at the same time.
Attaching the chain to the tank lever should be the solution.
Aug 13, 2010 | Fluidmaster INC #B1F09 9" Faucet Connector
After installing a new Fluidmaster 400A a few months ago, the refill tube started running constantly - not at 100% like when we flush it but enough that it always sounds like it's running and I would guess...
With the fluidmaster you should have found instructions on how to take it apart and flush it out if dirt gets in the valve...
If not look up the fluid master website, the instructions are there...
You simply have dirt in the needle valve...
heatman101
Aug 07, 2010 | Home
I have a toto toilet that doesn't start to refill until a couple of minutes after I flush. Any ideas. Thanks.
Several ideas. Start to fill? Have you looked inside the tank to see what's going on? If it just filling very slowly, then you most likely have some calcuim build up inside your flush valve blocking some flow, if this is the case you will have to clean the flush valve. If your flush valve is staying up and the toilet is "running" unitil the float drops. The float (either the arm ballcock style, or newer fluidmaster) is rubbing on either the flush lever or side of the tank, and taking longer to drop to let the water start flowing. I
Jun 23, 2010 | Toto Toilets ST784S 12 Sedona Beige...
Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Apr 11, 2009 | Home
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
1,110 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
