Question about Kenmore 21.8 cu. ft. Side-by-Side Refrigerator with Fresh-n-Ready Bin
What is the fresh and ready bin used for? - Kenmore 21.8 cu. ft. Side-by-Side Refrigerator with Fresh-n-Ready Bin
The fresh and ready bin is used for fruit. You can place various fruits in the tilt out bin and grapes in the berry basket. The berry basket is made do it can be lifted out of the assembly and run under the faucet to rinse your grapes (it has holes in the bottom). The entire fresh and ready assembly is manufactured by a Whirlpool supplier in Southern Indiana.
Posted on Oct 10, 2009
Why does water not shut off after making ice
Is the bin drain line and dump drain line tied together. If so then it is melting ice from the bin. now when ice machine starts up it will dump the old water in sump tray so it will be fresh water during new freeze cycle.
Jun 25, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
How do you select good sunflower seeds?
Just as with any other food that you may purchase in the bulk section, make sure that the bins containing the sunflower seeds are covered and that the store has a good product turnover so as to ensure the seeds' maximal freshness.
When purchasing unshelled seeds, make sure that the shells are not broken or dirty. Additionally, they should be firm and not have a limp texture. When purchasing shelled seeds, avoid those that appear yellowish in color as they have probably gone rancid. In addition, if you are purchasing sunflower seeds from a bulk bin, smell them to ensure that they are still fresh and have not spoiled.
-http://www.whfoods.com/genpage.php?tname=foodspice&dbid=57
Apr 17, 2013 | Cooking
Ice maker makes ice but will dispense through door. Checked and it is not clogged.
Good day!!!
This could be because the ice is clumped in the ice bin. When the automatic defrost cycle occurs, heat is transferred to the freezer area. This can cause the cubes to melt slightly and refreeze back together. You can take the bin out and give it a good shake, or simply discard the cubes and start over with a fresh batch of ice cubes. By increasing the amount of food in the freezer compartment, you may be able to buffer the heat that comes from the defrost cycle and avoid clumping issues. If you have a large ice bin and hardly use any ice, it is possible that the cubes have gotten stuck together just from the weight of the cubes on top of others.
I hope this information will be helpful...Thanks for using fixya...
Sep 09, 2011 | Hotpoint HSM25GFRSA
Model 106.57789704 - ice wont release into door bin
This probably is not what you wanted to hear but... I recommend you to the human manual defrost method to free things up as a result of the ice that built up post power failure. That somewhat messy method being:
1. Unplug the unit.
2. Remove Freezer contents (You do not need to empty fresh food contents)
3. Place a fan blowing into the freezer section for around 2 hours. (Messy part so be ready to tend to the drips with rags & mop)
AFTER 2 HOURS
4. Take a rag or sponge and remove most of the water out of the ice maker as best as you can after the manual defrost.
5. Completely empty the ice bin of all ice or water paying particular attention to the auger making sure there is no ice at all in the auger.
6. Plug in the unit.
7. Reload Freezer contents.
This should get things back to normal. If not there is much more that can be attempted. At this time I really believe that the above procedures will normalize your unit. If and when you need more assistance just respond here I and I will gladly assist you.
Thanks for choosing FixYa.
Kelly
Jul 29, 2010 | Kenmore Refrigerators
Ice maker is spilling ice on the racks below
This is a common issue with all makes and models. Best solution is to turn off the IM when bin is full if yu are not heavy users of ice. I try to empty the bin and start fresh once a week if we have not been using it regularly
Eric.
Dec 23, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
How to fix waste in full
Peel too many apples for a Thanksgiving pie, and the "waste" (the apple-peels) will fill your garbage-bin. So, you have to empty-out the garbage-bin, or replace the full garbage-bin with a brand-new _empty_ garbage bin.
Print too many pages, and the "waste" ink will fill the miniature waste-bin inside the printer. Take the printer to a qualified technician, and have him/her either empty the bin, or replace the sponge in the bin with a fresh sponge.
Nov 25, 2009 | Cannon MULTIPASS C530 Printer
Small amt. of water dripping from behind veggie bin
Hi, It sounds like the tank for the fresh water dispenser. Is it coming from the tank on the back wall of the fresh food section?
I can not find the part # but, if this is the source of the leak, I can give other ideas.
Please let me know if I can assist you further.
Vic
May 24, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ice doesn't come out into glass. Makes some ice but is larger pieces stuck together or flat pieces in bottom of container. Green light in back of container is on. I set the freezer to colder temp but...
You are not using enough ice.
You may need to dump the bin every week or so and keep fresh ice in the bin.
When you go through several defrost cycles the ice tends to eventually melt and stick together.
Mar 10, 2009 | Refrigerators
Fridigaire side by side ice maker not dispensing
The auger does not have the strength to do it's job when a lot of ice is in the way. You can defrost the icemaker with a blow dryer. It will be messy so be ready with lots of towels or a mop.
Once the unit is dry, spray the auger with PAM or some similar cooking spray. Then let it recycle.
You can temporarily prevent more fresh water from entering the ice maker by simply moving the wire arm to the up position
Jan 31, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
2,262 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
