Question about Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05
When i turn jacuzzi on it primes and one of the pumps/jets turns on, then when i try to turn the other jet/pump on it makes a funny sound and blows a fuse i checked to see if any air is in the line but none can anyone help?
My pump turns off and on every two to three seconds.
Posted on Mar 24, 2011
  • 990 Answers
This is probally a bad motor, the sound you hear is the motor trying to start but when it can't the breaker trips. If it takes a start capacitor it may be this rather than a motor but you will have to pull the motor to see. It may also be a clog in the pump but the motor sounds like the problem.
Posted on Oct 04, 2009
Why do jets turn on, then shut off?
the motor protection device is sensing to many amps. could be a flow restriction or the pump motor bearings are going bad.
Mar 06, 2016 | Jacuzzi Home
Aqualux whirlpool tub how do I clean jets?
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Nov 02, 2012 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
I've got no water coming thru the side jets in my pool, even though water is pouring through the jacuzzi jets. The jacuzzi is all part of the pool.
This is an ether or situation. Most systems now are set up with three way valves and if you turn the jets on you will shut the pool returns down. If you turn the pool back on you will shut the spa jets off.
Sep 27, 2010 | AO Smith 1 hp Swimming Pool - Jet / Well...
1 set of 4 jets won't work properly?Jacuzzi 6 place tub any solutions?
check the face of the jet trim to make sure it is turned on. most jets today turn clockwise and counter clockwise to turn the water on/off on each jet.
Feb 27, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
One out of 5 jacuzzi outlet works with force, the other do not even when the air flow is totally open.
try turning off the 5 previous jets in order to see if there is enough water flow to get to the last jet.
Feb 17, 2009 | Jacuzzi Cyget In Ground Pool Pumps
Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Feb 11, 2009 | Home
Trash come out of jets
Sounds like the hoses to the jets are the pump are breaking down and pieces coming off. Replace the bad hoze(s).
Feb 01, 2009 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Jacuzzi jet pump doesn't produce much bubbles
you need to turn the air on should be some sort of cap or screw in type thing to let the air in open it
Jan 17, 2009 | Pool & Spa
Jacuzzi Balboa R574 System for 1 2 Speed Pump Value 52221 05 Logo
186 people viewed this question
Top Jacuzzi Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jacuzzi Garden Expert? Answer questions, earn points and help others
