Question about GE Refrigerators
Ice and water no despencing and the light not
Ice and water no dispensing and the light not coming on. it is like there is no power getting to the door.
this started after I replaced the light switch on the freezer door side.
this is a side by side 25cubec foot
  • GE Master
  • 4,654 Answers
You have either a mother board failure, dispenser board failure or a broken connection in the wiring leading to the dispenser control. Thanks Sea Breeze
Posted on Sep 29, 2009
Water dispenser not working
Should have posted the model number, based on your issue, it sounds like a intermittent water valve, should be replaced,a bad dispenser switch, or a faulty relay on the main board.
Apr 28, 2014 | GE Refrigerators
I have a gsl25jf side by side. Ice will not dispense - ice continuess to be made. Water will dispense - after you try to have ice dispense from the door there seems to be a clicking sound the lights dim on...
PULL THE ICE DESPENCER OUT AND RUN HOT WATER OVER IT AND START FRESH . IT MIGHT JUST HAVE A ICE JAM, I HAVE SEEN THIS BEFORE, THE ICE BUILDS UP IN LAYERS AND WONT ALLOW THE TREY TO SIT IN SNUG TO THE MOTOR .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Ice/Water despenser Problem- not working(no lights on the button)
Replace the main control board . Pt # WR55X10942 is the part number . The dispenser board has lost communication with the main board . The main control board is behind the refrig , behind the small 8X10 inch panel . There are 6-8 group plugs which will only fit in perspective plugins , so this board is easily replaceable . Cost of board is about $150.00 .
Jul 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not working, the water despencer is ok, so i know there is water coming in ,it is in on position, no ice is stuck,what do i look for? next move
When the ice is frozen hard the ice maker has a heater that activates so the ice can be released, the a rotating mechanism rotates to push the ice out of the ice maker. Then cycle starts again by dispensing water in the tray. A lot of times the ice maker itself is defective and must be replaced. They are just attached by two screws and plugs into the freezer plug.
Feb 12, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water from despenser but not to the ice maker
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear. If it doesn't
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 22, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
WHIRLPOOL ICEMAKER DESPENCER STOPPED WORKING.
It is either the motor going bad or the switch at the ice lever. The little micro switch that is activated by the ice lever is likely held in place by two little, week, plastic pins. They break easily. After one pin breaks, the switch can still be close by the lever, but it is hit and miss. It is a ****** to replace the bracket unless you have some experiance. One other long shot would be the freezer door light switch that shuts power off to the dispenser when the door is open.
Apr 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Hotpoint side by side Model HSS25GFPJWW
Your problems are the power board for sure. I have the same refrigerator and have read dozens of forums and advise pages looking for answers. If you let the problem countinue your fridge will completely stop cooling and all your food will be trash as has happened to me.
Symptoms: Fan in the back starts to make click or flopping sound as it tries to start up. Ice despenser doesent despense ice. water works sometimes. Eventually you notice your food defrosting partially and then refreezing as the defrost timer stops working which is controlled by the power board. Light dims and pulses when you hold the Ice despencer in. If you remove the light for the dispencer your water will work fine as long as the fan isnt making the clicking noise. Fan will eventually start up and run.
FYI GE customer Care is useless
Jan 03, 2008 | Refrigerators
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
