Question about Admiral Refrigerators
Why would top of refridgerater get humidity - Admiral Refrigerators
  • Admiral Master
  • 4,654 Answers
Leak in door seals or defrost drain is blocked. Sea Breeze
Posted on Sep 29, 2009
  • John Tripp
    John Tripp Sep 29, 2009
    I believe your condensate defrost drain is either blocked or frozen over behind the rear panel of your freezer. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, there is also a short movie that makes the repair look easy, Thanks Sea Breeze
    click on link below
    Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
    If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
    appliancepartsse@yahoo.com
    SEA BREEZE TIP'S
    http://servicepartstec.blogspot.com/
    http://appliancepartsse.blogspot.com
Maytag refridgerater-model number RTT1700E-water drips from top of inside of fridge.prw50@msn.com
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 26, 2010 | Maytag Refrigerators
If I want low humidity in the (vegetables/fruits) crisper[s]
This is usually just a switch for a mullion heater that prevents condensation from building on the outside of the fridge between the doors. It has nothing to do with humidity inside the refrigerator. If your house is humid as not running an air conditioner, set the switch to high.
Jun 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
My Whirlpool refridgerater on the bottm has stop getting cold, but the freezer on the top is still working perfectly. Could the amount of food in my freezer effect the temperatue of my refridgerater?
highly unlikely u usually have a duct that goes thru from the freezer to the refrigerator make sure this channel is open and not blocked or u have a fan in the refrigerator one of the 2 if u have a fan it will be behind a panel in the back of the refrigerator if u have a fan it may not be running if its not running check voltage and make sure u r getting power to the fan if so then spin the blade and make sure it spins freely if it does then u have a bad motor replace it its very simple and cheap hope this helps
Feb 27, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerater-freezer model#
check relay in compressor. check if compressor is running
Feb 08, 2010 | Refrigerators
Crisper has humidity
wipe with dry cloth ,this is normal.......or veg would freeze........
Feb 07, 2010 | Refrigerators
My refridgerater went out Saturday and now my freezer went out last night. what do you think it would be?
The overload relays at the side of the compressor have gone bad. Not an expensive repair and not hard to do. Replace the overloads and you're back in business.
Feb 01, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Mar 29, 2009 | Kenmore Refrigerators
Refridgerater
It could be the defrost thermostat located on the condenser coil on the left side of the fan in the freezer compartment... or else it could be the defrost timer located in the refrigerator behind the dome cover... defrost the freezer and make sure the drain tube is not blocked nor the air passage which blow cold air from freezer to refrigerator compartment below. Water should drip from freezer down hole into tube to an evaporator pan on the top of the compressor near the floor in the back. Make sure the tube is free flowing by pouring some hot water down it before restarting refrigerator. Rarely the defrost heating element shorts, but a simple continuity test will determine if that is o.k. Make sure the refrigerator is uplugged before checking any of these areas... there's 120 volts all about and with water and ice it can cause quite a jolt!
Oct 05, 2008 | Roper RT14DKX Top Freezer Refrigerator
Refrigerator
there is a peice sticking out the back wall of the refridgerater compartment just under the top back wall that goes to the defrost drain see if its clear its a square peice also check the drain hose at the back of the unit at the bottom to see if the hose is clear some times they get clogged with alge and wont drain
Mar 10, 2008 | Kenmore 63074 Top Freezer Refrigerator
Need help with fridge
how do you get to fan at in back of refridgerater
Dec 27, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
