Question about Car Audio & Video
Sound system problems
I installed a sound system on a 2000 Honda Civic and for some reason it doesn't work too well. you can hear the sound of the motor when you chenge gears in the system and it doesn't go too well with me. can anyone tell what is wrong or if i installed something wrong or connected the wires wrong?
  • 127 Answers
You need to make sure your ground wires are properly connected and are making good contact. Engine noise can appear on certain radio frequencies if this isn't done correctly.
Posted on Sep 29, 2009
Why is my 2000 honda civic ex keep shutting off when it gets over 4000 rpms
After 14 years I think it would be reasonable to have bad catalytic converter. Is there some reason your not accepting this?
May 04, 2014 | 2000 Honda Civic
Dashboard lights flickering 2014 Honda Pilot - 3 weeks old
Go back to installer & have him inter grate the system better ? sounds like factory alarm responding not absorbing.
Dec 23, 2013 | 2000 Honda Civic
03 civic heat doesn't work unless driving
no that is a water pump or a stuck thermostat. see when you are driving the coolant is going through the system which means the faster you go the faster the water pump goes and more pressure on the thermostat. you have a stuck thermostat
Dec 14, 2012 | 2003 Honda Civic
Firing problems 2000 honda civic
From easiest to hardest on fixing would be to use fuel cleaner, if that doesn't work then you need to change the fuel filter, if that doesn't work then you need to check your injectors, if it still isn't fixed then you need to pull and clean (and possibly replace) your spark plugs.
Oct 10, 2012 | 2000 Honda Civic
Improve a sound system on a honda civic 2008
good day Sir, try to install a sub woopers and amf. i hope this tips will help.
May 09, 2010 | 2008 Honda Civic
Knock sensor in a honda civic 2000
It is located Under hood, center, rear engine area, below intake manifold, mounted in engine block . Simple to replace unplug unscrew. install reverse of removal.
Dec 20, 2009 | 2000 Honda Civic
Honda civic 2000 problem code PO420
P0420: Calayst system efficiency below threshold (Bank no. 1)
You can clear the code by turning your engine off, locating fuse number 12 in your under hood fuse box (backup, radio 7.5A) and pulling that fuse for about 10 seconds. If the code comes back, it was not a glitch and I would have the code checked out (has to do with you catalytic converter, I believe).
Hope this helps you.
Nov 22, 2009 | 2000 Honda Civic
My 2000 honda civic engine light on code p1456
Hey I had the same code and I have a 2000 honda civic lx. My cousin works at honda and drives a '96 honda civic and he has had that code before on his car as well.
First thing he came up with was that the catalytic converter was cracked. We checked mines, and lo and behold, that's what it was.
Look under your hood, and there should be a catalytic converter with a sensor sticking out of it. It is connected to the exhaust manifold and the sensor sticks out of the heat shield. Around the sensor, look for a crack. If there's a crack, that's your problem.
Apr 23, 2009 | 2000 Honda Civic
Viper 791 XV Automatic Start Not Working
Viper Working installed in my 2000 Honda Civic. It's the 791 XV model I nite diagram
Nov 05, 2008 | Viper Security and Remote Start System...
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
