your password is the last 4 digits of your cell # if you haven't changed it...
if the phone is asking for the security code as soon as you switch it on then i can give you the master code that resets the code to what it was when new usually 12345 the code only works if its asking for security code when you switch phone on. Also the code is only accepted if the code hasnt been entered wrong more than 5 times if it has been entered wrong more than 5 times then the code wont work the code is in my next post ok let me know if you need further assistance ok...or try this Security Mastercode: 5001637057
Hi i can help you and get a master code for your phone this code only works if your phone is asking for the code when you switch it on also the code wont work if you have entered the code wrong more than five times. If the wrong code has been entered more than 5 times then the phone is hard locked and then you need flash lead and unlocking software.
If you want the master code then i need your imei number its on back of phone under the batery and looks like 12345/134/14566 it should be 15 numbers long.
If you can use the phone and just need to change the code then the master code wont work and youll need lead and software ok it only works if the phone is locked and the code hasnt bee entered wrong more than 5 times
Hi yes your right i can get you a master code for your phone but this code only works if the wrong code hasnt been entered wrong more than 5 times and it also only works if the phone is asking for the code when you switch it on. If the wrong code has been entered wrong more than 5 times then you need to get a flash lead and unlocking software as the phone will be locked out from using over ride code ok. Also if you have acess to your phone and you just need to change the code but can still use the phone then to change the code you need the lead and software. If the phones locked and its asking for the code when you switch it on then the code i can give you resets the code and removes it untill you want to put a code back on the phone it resets it to what it was when new ok What i need to get the code is your imei number its on back of phone under the battery and looks like 123456/12/1234567 its about 15 numbers long once i have this i can use the software that i have and generate your master code ok so let me know then i can help you ok speak soon
hi i can help you but the master code will only work if the phone is asking for the code when you switch it on also it will only work if the wrong code hasnt been entered more than 5 times if it has then your going to need flash lead and unlocking software witch costs more than the phone. Anyway if you want the master code for your phone then i need your imei number so that i can generate your master code as each phone has a certain master code set by the imei number. The imei number is located on back of phone under battery and looks similar to 123456/12/123456 its about 15 numbers long once i have this i can get the master code for your phone ok speak soon
hi the master code only works if the wrong code hasnt been entered wrong more than 5 times if it has then you need flash lead and unlocking software witch costs more than the phone i have one as its my job but thats no good to you is it anyway here is your master code 5717063440 Also this code only works if the phone asks for code when its switched on ok let me know if you need further assistance
Hi i can give you a master code but this code will only work if the phone is asking for the code when you switch it on and also it will only work if the wrong code hasnt been entered more than 5 times if it has then you need a flash lead and unlocking software that costs more than the phone. If the phone isnt asking for the security code and you just want to change it then you need flash lead to scan the phone and see what the code is. Anyway here is the master code enter this when you switch the phone on ok. 7546711501 let me know if you need further assistance ok
hi i can give you the master code but this code only works if the phone is asking for the security code when you switch it on also the code will only work if the wrong code hasnt been entered more than five times if it has been entered more than five times then no code will unlock the phone and you will need to buy flash lead and unlocking software but this will cost more than the phone so its not worth it. If the phone is asking for security code when switched on then enter this code 5672162562 after enering this code it will then give you full acess to the phone it also resets the security code to what it was new but unless you want the security code on the phone then the code i gave you will remove any locks on the phone ok let me know if you need further assistance ok
Hi if the phone is asking for the security code when you switch it on then i can help you but the master code only works if the wrong code hasnt been entered more than five times if it has then the only way to ulnock it is using a flash lead and unlocking software. If you want the master code then i need your imei number its located under battery and looks like 123456/12/1234567 its 15 numbers long once i have this i can generate your master code ok let me know speak soon
hi i can get you a master code but this only works if the wrong code hasnt been entered more than 5 times if it has been entered more than 5 times then the only way to unlock it is by buying flash lead and unlocking software if you have not entered the code wrong more than 5 times then i can help you but i will need imei number to do this this number is located on back of phone under battery and looks like 123456/12/1234567 once i have this code i can generate your master code ok let me know and i assist you further ok
hi if the phone is asking for the security code as soon as you switch it on then i can give you the master code that resets the code to what it was when new usually 12345 the code only works if its asking for security code when you switch phone on. Also the code is only accepted if the code hasnt been entered wrong more than 5 times if it has been entered wrong more than 5 times then the code wont work the code is in my next post ok let me know if you need further assistance ok
