Question about Hampton Bay 24002 Ceiling Fan
I just changed the fan light switch in my fan and my fan doesn't turn off . i connected the wires the way i took them off light went with light and the # 1 wire went with #1 and so fourth can anyone help me?
  • 101 Answers
Lol did you get a 3 wire switch ... they are made to use with more then 1 switch ie: in a room with doors @ opposite sides you may have 2 switches that work the same light or fan. This may be your problem, check the package ... if not check the switch, good luck!!
Posted on Sep 29, 2009
Casablanca Isatope 52 inch fan not working
The combination of wall switch control and remote control tends to throw the unit into a tizzy. Try disconnecting power at the source and starting all over again. You may have to abandon wall switch control and rely solely on the remote.
Apr 02, 2017 | Casablanca Fan Televison & Video
Fan works fine, lights don't. Could it be the remote?
Had this happen to me and it was a hunter fan. Similar problem. Fan worked,lights went out. Took light bulbs out, lowered the light fixture. Tested power coming from the ceiling to the quick connect pins for lights. The power was good. So the Problem's in the light kit. Turns out the government requires all new fans to have certain wattage to lights, set at 190. So 3 60w bulbs or 4 40w. Inside the light kit is a limitor hooked to the black power wire coming from the quick connect,It is smaller wire and mine was pink into limitor and white coming out. Not very big. This went bad so i called Hunter, sending new light kit, but I just wired straight black to black wire bypassed that limitor and lights work fine
Aug 29, 2012 | Hampton Bay 24750 Huntington III Ceiling...
Light turns on but fan doesn't. This fan had a
You wired it correctly . It might be your fan's on &off switch that went out or your motor.
Sep 01, 2011 | Hampton Bay Dryers
We have a ceiling fan Apollo 52' Model 355-6788 but we don't have any instructions on how to put it up. Please send us instructions on how to do this.
On the remote part that goes inside the fan, it has five wire on it. One Red wire marked L goes to black switch wire from switch or Hot wire. Other Red wire goes to Net. wire from switch.or feed.Then you have A black, a blue & a white. They connect to wires from the fan. When finished connect turn light switch on, leave on & used remote control. Top left button controls the fan on/off. bottom left button controls light on/off.dimmer. There you go, all the know how to connect remote & fan/light up. Good Lucky.
P.S. You will need to buy a 9v battery for the remote, it doesn't come with it
Aug 13, 2011 | Heating & Cooling
Car keeps over heating because fan doesn't turn on
Your car has electric fans and they are activated by a switch that is mounted in the bottom of the radiator. What you need to do is verify first that the fan motor is good. After that then you want to "jumper" the switch and see if the fan runs. Jumpering is when you disconnect the wire from the switch and use a piece of wire to connect the wires of the harness together as if the switch was "turned on"..If the fan works then the switch is probably bad, If it doesn't then I would look for the fan "relay"..
Jul 11, 2011 | 2000 Ford Focus
INSTALLED NEW LIGHT SWITCH IN CEILING FAN LIGHT PULL CHAIN TYPE AND THE LIGHTS WILL NOT TURN OFF WITH THE PULL CHAIN? THERE ARE 4 WHT WIRES AND 4 BLK WIRES IN LIGHT KIT WERE DO THE 2 WIRES FROM THE NEW...
twist the 4 black wires from the lights together and use a wirenut to either connect them to one side of the switch or to a pigtail that will go into one side of the switch. The other side of the switch will be wired to the hot wire coming from the fan meant for the light kit. All of the whit wires get twisted together and connected to the neutral light wire coming from the fan. If you've already connected it that way and it doesn't work, the switch may be defective.
Jun 26, 2011 | Westinghouse Electric Ceiling Fan Light...
I was trying to install a fan control switch on my Patton floor fan and took the 3 speed switch out and disconnected the wires and cannot figure out what wires (too many colored wires) to connect to the 2...
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
Dec 28, 2010 | Patton U2-1487 Floor / Box Fan
Problem with lights on install of a ceiling fan/light
ok...assuming the blue wire is the second wire coming from the light switch, it should be connected seperately to the black wire leading to the light(s). so the black lead of the switch should be connected to the power wire from the ceiling box and the blue wire should be connected to the black lead that goes to the lights. it sounds like you have the light leads connected to the main power, so the light switch would be bypassed, thus not operating correctly.
all white wires should be connected together unless one is being used as a return power from the wall switch, (which is often done).
hope this helps..........................jay
Mar 20, 2009 | Dryers
Ceiling fan and light wiring, 2 switches, 1 romexHunt
If you have only one black and one white in the ceiling to connect the fan / light to , then you have only one switch for this ceiling box. The fan / light will connect the white wires together and then the two colored wires on the fan to the black ceiling wire. In order to use separate switches for the fan and the lighht a 4 wire cable must go from the switches to the light so you have a red and black wire to switch the two separately .
Oct 30, 2008 | Hunter Vaulted Ceiling Mount - Antique...
Hampton Bay 326-946
Chances are the wire nut came off the connection for the light unit. If you're handy, shut off the fan mechanism at the fan (pull chain until fan is off), then turn off the power at the breaker box, ensure the power is off at the light switch and proceed to unscrew the fixture from the mounting unit (attached to the ceiling).
Carefully support the fan unit with one hand ( there should be a silver grounding wire that will help support the unit - unless it wasn't installed properly in which case the unit will be heavy - try to balance on the ladder if it's tall enough). Look for the white and black wires - one will be for the fan unit, one for the light unit.
Check to see both are securely attached by wire nuts. If one is loose or has come apart, carefully re-twist the wires tight (turn to the right as this is the way the wire nut twists on so it will stay together when you replace the wire nut. If when you replace the wire nut the wires are still loose, replace the wire nut - they do get old and tired.
At this point I would turn on the power at the breaker box and turn on the switch for the fan on the wall. Then try the light unit - see if that fixed the problem. If it has, turn off power again, replace the unit the same way you took it down - if not, there is a problem in the internal wiring . . . check with warranty depot.
Hope this helps,
Lauri
Dec 14, 2007 | Hampton Bay 24750 Huntington III Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
52 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
