Question about Canon PowerShot A95 Digital Camera
WHAT DOES IT MEAN WHEN THE SCREEN IS BLACK AND SAYS E18 AND MAKES A VERY STRANGE NOISE AND i CAN'T TAKE A PICTURE.USUALLY IF I TURN IT ON AND OFF SEVERAL TIMES THIS WILL GO AWAY
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Sep 30, 2009
My acer monitor displays the acer background, makes a noise like a buzzing sound and goes black, and then after all my settings and background picture and information are complete and up, the monitar...
It sounds like a backlight or inverter problem. You can verify this by using a bright light to shine on the screen surface. If you can see the picture (but it will be very dark) that means that the backlight which illuminates the screen from behind. You would have to replace the inverter to test it, but there is good news: These are pretty difficult to find parts for, and not an easy repair for an amateur; acer products usually have a 3 year warranty on the backlight/inverter system, so I would start there.
May 25, 2011 | Acer V193W 19 inch LCD Monitor
When i turn my cameraon the lens opens ans then shuts automatically with an e18 message on the screen and then makes a strange whirring noise
Go to this website for help. This is a common problem and there is an actual website devoted to this very problem. www.e18error.com
May 06, 2011 | Canon PowerShot A80 Digital Camera
AKAI PT5492S - Makes a ticking noise,black
This usually is indicative of the EXTREMELY HIGH VOLTAGE anode connection somewhere between the flyback transformer and one or more of the crt picture tubes or the splitter. Being that this circuit has a running voltage potential of over 30,000 volts if you are not familiar with these YOU CAN BE KILLED messing with it!!! What happens is that there is a breakdown of insulation over time usually from dirt or other environmental contamination. Usually a good cleaning and replacing the HV anode wire that has failed. (hint) it will be the one that the "ticking noise" is coming from. The ticking noise is actually the high voltage arcing to the chassis/ground.
Be careful!!!!
Dec 27, 2009 | Akai PT5492S 54" Rear Projection...
My Daewoo TV screen just went all Blank n Black suddenly while it was running all fine Then this was accompanied by a strange clicking sound and now whenever i turn it on,it just shows nothing(blank...
The set has developed a short either in the power supply or the horizontal/high voltage circuit. The power supply makes a weird noise when it gets overloaded. This can get complicated so have a repair shop check it out for you. Thanks
Nov 01, 2009 | Daewoo DTQ-13V1FC TV
My Samsung HLP4663WX has no picture, can't power off
it may be a bad DMD board. This is usually the problem when you get the three lights of death.
Sep 17, 2009 | Samsung Televison & Video
Tv will not turn on, just makes a clicking sound
Brother this is problem usually  when either the fly-back (picture tube transformer )or tube  voltage regulator  Transistor is damaged or the picture tube has a short
Best of luck
Aug 12, 2009 | Panasonic Televison & Video
Dlp TV won't turn on
possible color wheel , or just a lamp. depending on what the noise sounded like. check out some videos on you tube on how to replace color wheel. Not to hard
May 27, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
RCA 52" D52w20 problem
My goes off a few seconds after turning it on. It does make a funny sound, like static on the tv.
Aug 26, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
A95 Trouble
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Dec 08, 2007 | Canon PowerShot A95 Digital Camera
Sony Wega 32"TV - noise on startup
The slight flash on the screen is usually because the CRT (picture tube) is holding a better than average charge and this is what we call "pre-glow" The noise that you hear, is that everytime you turn it on or just after it has been off for a while? If only after the set has been sitting off for a while then your noise is the internal degauser for the CRT and that noise is 100% normal. The degausers in Sony TV's are so strong they usually make the plastic cabinet vibrate a bit.
Apr 18, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Canon PowerShot A95 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
