Question about Kitchen Ranges
I have a Jeunesse No. 3 firebox, made in Scotland and supplied by John Chambers and sons, who operated a buisiness in Nz from the late 1800's. It will have to be installed as an untested appliance if I cant locate manufacturers installation instructions and the council might have some issues with that so i'm looking for installation instructions to smooth out the process. It has never been used and is at the engineers getting certified at the moment. it you could help that would be great:) i have googles all the words and only come up with history of the company in archives. Cheers:)
MJS_1
  • 150 Answers
SOURCE: Blaupunkt flattening battery
I would be concerned about the amount of current required to kill a car battery in a week:
Let's assume that 1 week = 24 * 7 = 168 Hrs
A typical, healthy car battery will deliver anywhere between,
45 to 70 Ampere-hours at small currents, depending on the
size of the car (check your car owners manual)
Assuming a weak battery has a 40 Ampere-hour reserve, it would require an average current of 250 milliamperes to drain
in a week, or about 3 watts of power.
While this does not seem like a lot, it certainly indicates
something is wrong, because the clock and station memory
in a radio should take a lot less than that.
The first step is to make sure that the radio is actually at fault,
not damaged wiring or another one of the dozens of electronic
systems in a modern automobile.
Don't trust your mechanic on this, I have never met a gear-head
that was any good in electronics, but they do come up with
some fairly captivating fish-stories when they do not
understand something. :)
1) The first step is to disconnect the radio and isolate the
problem.
2) Remove the radio and hook it up to a 12V DC supply,
or battery through a digital milliamp-meter. Check the
current with the radio shut off.
3) Anything over about 10 mA or so is BAD.
4) If the radio draws any significant current with the switch
shut off, look for a bad switch or a leaky capacitor on the
B+ wire (before the switch, so it should not be hard to find)
Another possibility is the clock/keep alive controller chip,
but this is less likely. The most likely culprit is probably
an old leaky capacitor (electrolytic or solid tantalum),
since these do tend to fail with age, vibration and extreme
temperatures in a car environment.
5) If the radio is at fault, you will need some knowledge and
electronic instruments to find the problem yourself.
A quick way to check an electrolytic or tantalum capacitor
is with an ohm-meter. Connect ohm-meter to the capacitor,
and watch the reading race to infinity as the capacitor charges
up. Then reverse the leads and watch it again. Once charged,
the capacitor should have infinite impedance.
6) If the radio is not at fault, it could be dozens of other
problems, ranging from the body control computer,
immobilizer, remote starter, parking lights, door-locks,
alarm system, bad wiring ... you name it.
7) You should be able to isolate it by measuring the battery
current, while pulling fuses one at a time.
8) Another possible cause is the battery itself, or a bad
(shorted) diode in the alternator. The best way to check
the alternator is with an oscilloscope, while the car is
running.
A bad diode will show up as a missing peak in the otherwise
regular pulse train.
9) Finally, don't over look the relays in the power distribution box.
These can over heat and stick in the ON position with the
ignition turned off.
Good luck, Martin
Posted on Jun 13, 2008
dahaka
  • 347 Answers
SOURCE: I am a new customer
Hello sushi1413,
check this link and see if it works.
http://www.juniperforum.com/index.php/topic,4423.0.html
Posted on Jul 17, 2008
  • 300 Answers
SOURCE: HP Digital Media Archive Pop UP
Sounds like you have may have it run on startup. Just to see you can use msconfig to temporarily disable it by following these steps:
That usually means that a program that starts when Windows starts isnt functioning correctly, You can test it by clixking Start > Run > type Msconfig and press enter. After that click the startup tab. Here you will see programs that load when Windows starts.
If you recognize the program thats causing the issue, simply click the box to the left of the item to uncheck it and click OK. You will then be prompted to restart.
As the machine restarts, check to see if the issue has disappeared.
If so, great. Be aware that you that you will be prompted with a "System Configuration Utility" dialog that lets you know you are using Msconfig. If you don't want to be warned of this, click the box that says "Dont show this message..." and click OK.
If not, run Msconfig again, and uncheck the next suspicious program and repeat the process until the problem disappears.
Below is a link with information on using Msconfig. It also has other links that include information of some of the programs that you might see in the startup window of Msconfig.
http://www.netsquirrel.com/msconfig/msconfig_xp.html
NOTE:
There's is a "Disable all" button under the startup tab. But I wouldn't suggest using that initially. It is better to uncheck them one at a time so you can see what is causing the issue.
Hope this helps. Please remember to rate this information.
Thanks
Posted on Nov 16, 2008
SOURCE: Valid operating systems fro Power Edge 1800
During the Windows XP setup you will need to provide the RAID driver using a pre-formated floppy disk.
Windows will ask you if you want to provide additional drivers and give you the key combination to use to do that.
Posted on Jan 22, 2009
SOURCE: problem with dell studio 1737 downgraded from vista to xp
Hi
Download your drivers from here
http://www.samsware.com/pageLib/index/index.php
Download the rar file for 1537 for your xp OS, read the pdf file which shows you the instruction on how to install drivers step by step.
Enjoy
Posted on Nov 04, 2009
Where can I get a trigger spring for my 312? I think the springs off 340 342 347 are compatable
Try chambers gunmakers Scotland they may have what you are looking for
Apr 11, 2016 | Optics
320d bmw - dde light on, black smoke from exhaust. is it safe to continue driving
Why is it you guys are not letting us know your names lately? The DDE warning light is related to the Digital Diesel Electronic injection system, hence the black smoke, as the management system is injecting too much fuel into the combustion chambers. Take the vehicle for a digital diagnostic scan. Safer to find out the actual problem before continuing with it on the road. Regards John
Sep 07, 2014 | BMW 320D Cars & Trucks
The gas flame on my 4 burner Chambers stove top is very high. How do I adjust it?
Now That the range operates like new, learn to use it. Don't die.
Jul 06, 2017 | Kitchen Ranges
Hi. My late 2006 GC Overland 5.7 with 48,000KM on it has an intermittent starting problem. Very occasionally when we start it it them stops immediately. The engine does start - but then dies. It does...
CUTE LAw
now all cars there cost 2x normal
there is no free, lunch.
sure
use scan tool
if the ASD relay drops out, it stalls
so if it is, the PCM then tells you why it dropped out the
relay on purpose
the car is 11 years old what is all this warranty bs.?
Mar 19, 2017 | 2006 Jeep Grand Cherokee
Presonus Firebox doesn't sync up.
1. check the drivers update for you device
This is found at the manufacturers site.
2. See if your device is compatible with the OS (operating system) on your laptop.
3. Check the connecting cable to see if you have a broken wire inside the "strain relief".
The cord at this point will have a puffy part that indicate that there is a broken cable.
Apr 16, 2010 | PreSonus Firebox 6x10 External Sound...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
