Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Harmony DPGT750GC1WW gas dryer not heating at all
I have a GE harmony gas dryer and the heat is not working at all.. The blower motor is working as it should, I checked the back and sure enough its pushing cold air out of the back. I can see that the glow rod is heating up, but I dont think that any gas is being turned on. Before this problem happened, I smelled gas inside the dryer while clothes were being dried. we cleaned it and it ran fine for about a month and now no heat at all. any suggustions on what to test to find out where the problem is?
SOURCE: How do you enter into the diagnostic mode
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
Posted on Jan 04, 2008
Master_Tech
  • 770 Answers
SOURCE: GE Profile Harmony Dryer - not drying clothes
Check your email
Posted on Apr 29, 2008
  • 54 Answers
SOURCE: GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
If you hear the blower ramp up when you start the dryer and it slowly ramps down or quits all together then you need to replace the blower.
Posted on Jul 04, 2008
  • 1810 Answers
SOURCE: How do you disassemble a GE harmony dryer
remove rear pannel and the motor is right there remove drum to acess the motor
remember to lay the dryer on an angle or even flat on it's face if you can to re insert the drum assembly and dont forget the belt
Posted on Jul 29, 2009
SOURCE: my GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
Posted on May 16, 2010
GE Profile Harmony Gas Dryer not heating/drying clothes.
let me ask you this does the ignitor glow orange but no flame when you have no heat?usually on a gas dryer if at first you have heat and then after 10 to 30 minutes no heat it's usually the gas coils located on top of the gas valve,common problem,after the coils cool down they will work again,that dryer is kind of complicated to work on seeing how it does have two motors in it but you should be able to get at the gas coils,if you send the model number i can look it up for you.but it sounds like you have bad gas coils,the only way to tell is run the dryer,when the heat stops working look at the ignitor,if it glows orange and the flame doesn't ignite you have bad gas coils.
Feb 14, 2014 | GE Profile Harmony DPGT750GC Gas Dryer
I have a ge harmony gas dryer and the blower isn't work can this cause a no heat issue
Yes. The blower draws the air from the heat source thru the tub and out the blower exhaust. This link should help with the Blower wheel assembly they also have diagrams or illustrations of your specific model
Sep 23, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
I need to find where the fuse is in my GE profile gas dryer DPGT750GC1WW. WE need to find this because our heat doesn't work so we need to replace the fuse
The model number you gave is for a gas dryer.
You will not find a thermal fuse in this dryer.
Your problem with no heat most likely lies in the gas valve or its subcomponents like the thermistor/flame sensor or igniter/glow coil.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge profile harmony gas dryer- no air flow in or out no heat
Replace the blower motor. Check condition of blower wheel and replace if found defective
Jan 16, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
We have a GE profile harmony gas dryer that is running but is not sucking in air, blowing out air or heating up.
This dryer has two motors one is specific for the blower system I'd guess the blower motor is not functioning and the dryer will not heat due to safety features. I would check those things but also check the venting from the back of the dryer to the outside of the house to make sure there is no blocked airflow just a general maintainance. Hope this helps.
Getting into a ge harmony dryer no heat
The blower motor went out, mine did twice I replaced it and the heat worked. The motor is pretty easy to change.
Nov 29, 2008 | GE Profile Harmony DPGT750EC Electric...
Ge dryer not venting
You have a bad blower motor. Best to call GE Factory Service to repair as there is probably still some kind of warranty on at least the part and it is easy for us (GE Techs) to replace but not easy if you have never replaced one. 30 minute job for me to do... GE 1-800-432-2737
Oct 24, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
144 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
