Question about Whirlpool Duet GHW9150P Front Load Washer
Door will not unlock
I have a whirlpool upright duet washing machine the door will not unlock to save my life. is there a manual unlock swith somewhere on the washing machine?
  • 1 more comment
  • Anonymous Mar 09, 2008
    I have a front loading Whirlpool washing machine. The machine hasn't started yet but the door is locked and won't open. The machine flashes F 22. We did everything the manual says to do but it won't start or unlock. Any suggestions?
  • Anonymous Mar 15, 2014
    Cycle is only half way done when machine broke. Cannot get door unlocked to replace broken part.
  • Anonymous Mar 22, 2014
    Need copy of manual
    President:
  • 1,294 Answers
If the water has not completely emptied, this won't allow the door to open. Check by lowering the outlet hose into a bowl. If a fair amount of water comes the problem is likely to be a pump or filter blockage
Posted on Dec 19, 2007
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
Door won't open on front load washer
Whirlpool is one of the finest brands in turning in international elegance appliances to its customers throughout the globe. Discuss the Washing machines of this firm, it's been rated as most owned appliance brand across the globe. while servicing this renowned branded washing machine, we are within the pivotal vicinity as top Whirlpool washing machine service center in Hyderabad.
http://aktechnoservice.com/whirlpool-washing-machine-service-center-in-hyderabad
whirlpool washing machine service center in hyderabad..-3rnaeo200p5jvdfftsegpbfu-3-0.jpg
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
How do i get a "whirlpool duet washing machine" to unlock its front door
Your answer is here in this youtube video.
Your problem is the washing machine still has water in it, so it locks the door.
Whirlpool Duet washer will not drain F21 Error Fix VERY EASY
Sep 03, 2015 | Washing Machines
Why will the washing machine door not unlock?
Sounds like you have a broken door lock, or a wire harness is loose or disconnected. Also make sure the door seal is not out of place.
May 01, 2014 | Whirlpool Duet Steam 4.1 Cu. Ft. Front...
Whirlpool Duet washer does not indicate end of cycle and unlock door
Most times this problem can be caused by a blocked tube to the pressure switch,..
Mar 03, 2014 | Whirlpool Washing Machines
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
I notice F22 error message on washer. Door seems to be jammed and will not unlock
This is a door lock failure code and it means the door lock is broken or just failed to unlock. Click on the links below for the detailed instructions for manually unlocking the door and replacing the door lock and switch assembly if it has indeed failed.
Manual Door Unlocking of Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Replacing the Door Lock and Switch Assembly on Whirlpool Duet and Kenmore Elite front-Load Washing Machines
Mar 12, 2011 | Kenmore HE2 Plus Front Load Washer
My whirlpool duet washer wfw8300sw02 won't unlock
Hi, I'm not sure why your door won't unlock but you can manually unlock it by removing the front panel under the door (3 screws at bottom of machine) with the panel off reach up just under the lock mechanisim and there should be a plastic tab hanging down, that is the manual release. Pull it down and your door should open. Remember, power off first! Good luck.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
May 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Unlock control lock in washing machine, whirlpool, duet
Hold control lock for 3 sec. It will make a sound and the door will unlock.
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
527 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
