Question about Food Processors
The motor on my kenwood food processor is working, but the shaft is not moving round, any ideas on how to fix? Unable to find tool to remove screws from base to open it up
    Sergeant:
  • 197 Answers
Belt broken possibly.
not easy to change
Posted on Sep 29, 2009
Testimonial: "thanks, looks like I will be buying a new one ! "
How do I remove my cracked support bearing on my Kitchenaid food processor 1333?+
Do you mean the bearing on the motor shaft within that circular plastic ring that moves up and down when moving the slicing thickness lever? If yes then a couple of screwdrivers under it one on each side to lever it up. At the same time it will force the black shaft sleeve up and off the motor shaft.
Oct 13, 2016 | KitchenAid Food Processors
Need to remove external covers so i can replace a gearbox on kenwood chef km001 mixer! any ideas?
Dont know what the problem is, you didnt say.
Merely take the screws out. Usually on the bottom
of the unit. Heres your big hint, possibly. Some screws
are hidden under the rubber feet.
Jul 31, 2014 | Kenwood KM336 Chef Food Processor
How do you remove the top and motor from KM200
I have the same problem, removed screws but it won't pass over the front gearbox spigot.
May 24, 2014 | Kenwood KM200 Chef Food Processor
Spindle / shaft or mixer bowl?
if you say the motor is running but no blades moves in the cup.it means the shaft which is connected to the blades and the motors break down.
so i refer u to open it and check which shaft part is broken,or take it to the mechanic.
Jan 05, 2014 | KitchenAid KFP740 Food Processor
How to tighten the nut on one of motor screws of a 7 cup kitchenaid kfp720 food processor
A gouge in the edge of a plastic button is not the end of the world, it has to come out to effect a repair. I use a sharp knife down the side, you can always blend any little damages to the plastic with the round shaft of a screwdriver.
Apr 28, 2012 | KitchenAid KFP720 7 Cups Food Processor
Cracked plastic sheath on the motor drive shaft
The shaft is spinning inside the sleeve. So is should not be hard to remove. With a DLC-7SP, I grabbed the spindle with some pliers, channel locks might do well and put a handle of a screwdriver between the pliers and the top deck and pried. Second attempt and it pulled up easily. Place the screwdriver beside one of the top deck screw covers to transfer force directly to the motor. Otherwise top deck would probably break.
Clean the old shaft to remove any contamination.
New one can be driven on with a hammer and block of wood.
Jul 08, 2010 | Cuisinart DLC-7SFP Pro Food Processor
Open th fp510 footprocessor
Remove the 5 screws underneath, then remove the 2 screws that hold the motor onto the base by inserting a thin phillips/star screwdriver through one of the gaps in the plastic grid underneath the motor.
Feb 07, 2010 | Kenwood Food Processors
I have a Robot Coupe R2 food processor that quite
It just a long shaft phillips screwdriver. The screws are located under the foot pads. They just pull out and then there are the four screws.
Dec 29, 2009 | Robot Coupe R2U Ultra Food Processor
How to put new shaft on cuisinart food processor model DLC-7E
Initial disclaimer: I am not recommending this course of action - my recommendation is to buy a new food processor. These units weren't designed for DIY repair, so this is going to be a difficult task. The final product probably isn't even going to be pretty. You are well out-of-warranty, or I wouldn't even consider posting this. First, make sure you have a DLC-7E shaft - the only way to get one at this point would be to buy a DLC-7E base from eBay or an after-market seller, as all of these were manufactured well over 20 years ago. I don't currently see any eBay listings for one, but they do crop up from time-to-time. Make sure the DLC-7E you are repairing and the old one from which you are wrenching the old shaft are unplugged and have been unplugged for an hour or longer just to be on the safe side. Unscrew the four screws on the bottom of the base on both units. If the bottom base does not come off after this, carefully pry out the four feet and unscrew any hidden screws that might be hidden underneath the feet (Careful - original feet cannot be ordered by normal means, and damage will only add to your total repair cost). Take note of the guts on the inside of both food processor bases - if you have to unscrew the motor body (4 screws that sit just underneath the top of the base), take note of everything that you are taking out so that you can put it back in its proper place when done. Wear leather gloves for safety. Please be aware that even an unplugged unit still has the potential to send several volts of electricity through your body - this is a potentially hazardous task. Once the motor body has been unscrewed and removed slightly (don't disconnect any wires or cables - just get the motor body out of your way), you will notice the old shaft that you intend on replacing. Look for any damage to the gears/bearing that surround this shaft. Try dabbing a small amount of USP-grade mineral oil on any bearings - clear away any dust or debris that may be obstructing the shaft from turning. Don't overapply the oil, or the wetness will seep into other electronic components in the motor and cause them to fail. Put your food processor back together, turn it on, and press the button/buttons on top of the base of the food processor with a pen with the food processor plugged in. If the shaft still won't turn, you definitely need to replace the old shaft (you can disregard some of these previous steps if your problem is that the spindle on the old shaft is worn).
Remove the screws and disassemble the processor base as described above. Since there is a layer of paint/coating surrounding the old motor shaft, removing the old shaft may cause paint flecking. Take the shaft from the one food processor base and insert it in the food processor you are trying to repair. Strip away any excess paint/coating from the new shaft. Make sure no paint flakes remain in the body of the food processor, or they will later cause more serious problems that will permanently damage your food processor - potential fire hazard as well. You will probably notice that the new shaft does not look as pretty as your original shaft, since the paint/coating will almost invariably get damaged in this process. Reassemble the base of the food processor, making sure no wires, etc. were knocked out of place in the process. This paint flecking will add to the cost of the repair - you may need to buy appliance body paint that dries to almost a rubbery consistency to make the final project look nice. All of the materials listed above could cost you $40 or more.
Like I said, I don't reccomend this course of action, but there's your answer.
Mar 11, 2009 | Cuisinart Food Processors
How do i seperate the housing on a robot coupe processor
There are 4 rubber shoes on the bottom of the white or gray base. Twist & pull these out. With a TORX long shank screwdriver (nothing else works, trust me) there is a screw way down in each hole. After removing the screws a gentle but firm bump should loosen the base. If you ever need to replace the motor, on the top around the drive shaft you will see three round plugs/disks, remove them by prying up with a pocket knife (works best) this will give you access to the three motor bolts.
Feb 20, 2009 | Food Processors
Food Processors Logo
157 people viewed this question
Top Food Processors Experts
Are you a Food Processor Expert? Answer questions, earn points and help others
