Question about Acer Aspire One Netbook 8.9" Notebook
Acer aspire one hit the floor and now has a cracked lcd case near right hinge - actually there is a chunk missing. They want 199 bucks to replace...Is there a way to buy a new lid and install it? thnx! Diana
  • 34 Answers
So u mean the Lcd has broken or only Hinch,
is there any display coming, If they are changing Lcd then go head, if they are chaning hinchi think its quite expensive,
Posted on Oct 04, 2009
  • 35 Answers
No, when you crack the casing it is costly to replace. it depends where it is on the computer. You could find someone cheaper maybe. or find the part your self cheaper then them and bring it in and have them install it. it will most likely be cheaper going that route.
Posted on Sep 29, 2009
We have a cracked lcd moniter. It is for an Acer Aspire 5315 15.4". How much would a repair like that cost?
As per Acer repair policy, cracked screen is not covered under standard warranty. They will charge you $199 inorder to replace the screen. However, if know any local retailer or tech you can consult with them.
Thanks and regards,
Anil.B.
Sep 07, 2010 | Acer Aspire 5315 Notebook
How much is a new LCD monited 15.4" for an Acer Aspire 5315?
Thanks and regards,
Anil.B.R
I can barely se the desktop,it is very dark. acer aspire 1710
It sounds like you are or have lost your backlight. In most cases this can be the inverter, it sits under the lcd panel behind the lcd bezel. Unless the unit was dropped or suffered a shock of some kind, I don't think it would be a broken ccfl backlight bulb. Check for loose connections at both ends of the inverter, sometimes these connectios get pulled because they run through the hinges and can get caught or rubbed bare. Below is the link to the service guide that will help in the disassembly. Inverters can be bought on Ebay for under 25 bucks. There is always the chance that this is the ccfl bulb, it is built into the lcd panel itself and therefore it is more cost effective to replace the entire panel then try to disassemble the lcd panel and replace the ccfl bulb. Good luck
http://tim.id.au/laptops/acer/aspire%201710.pdf
Jul 25, 2010 | Acer Aspire 1710 Notebook
Acer laptop crack at the back of LCD near the hinges.
In my experience, I have been able to replace the LCD Bezel to fix the crack. You can order this from any online parts store if you are a Do-It-Yourself type or any computer support company could help. Good Luck
Frank
Jul 27, 2009 | Acer Extensa 503T Notebook
Acer Aspire 3613 cracks near hinges.
you can lift up the little round circles take out all screws,take top off, to lcd find the little gold nuts that the screws go into, try to put them back in plastic holes with super or gorilla glue,
or order screen parts on ebay, hinges usually get worse unless you find a way to secure those brackets attached to hinges
Mar 13, 2009 | Acer Aspire 3613WLMi Notebook
Cracks near hinge Acer 3613 laptop
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
Mar 12, 2009 | Acer Aspire 5050-3242 Notebook
My laptot as started cracking near the left hand hinge
superglue it or epoxy it back together. that's about all you can do.
Feb 05, 2009 | Acer Computers & Internet
Cracked front cover at hinges
What does work is this-
Superglue the cracked lid as you WILL have one of these if you are reading this post- dont rush, I did about 10 glue applications over a few days to let it set correctly.
Next remove the offending hinges. You will see to spring/pressed steel curves in the body of the hinge, Next hack saw one (the outer is easier to get to) of these off, this frees the hinge up very well. Worked for me so give it a try
Feb 18, 2008 | Acer Aspire 3610 Notebook
Acer Aspire One Netbook 8.9" Notebook Logo
90 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
