Question about Nintendo DS Lite Console
Nintendo DS LITE Configuring Problem
I am having problems configuring my DS Lite, it configures all the points apart from the top RHS. When i try to use the RHS of the Screen the stylus will not match up the the area on this side of the screen i am touching, Any Suggestions?
  • 152 Answers
Try recalibrating the screen.
Posted on Dec 24, 2007
How to get wi fi on the ds lite
you need a wi-fi enabled game. you would go into nintendo wfc, and then tap configure (in the game)
Jul 04, 2011 | Nintendo DS Lite Console
Why wont my ds lite connect to my wi fi
Its happening because you have not configured the access point on your DS. or Sounds like you haven't put the correct WEP keys of your Router correctly into your DS
Mar 03, 2011 | Nintendo DS Lite Console
How to get wifi
Hi. Please see procedure below:
  • When you try to connect your Nintendo DS on the internet, here are the steps that occur:
  • You choose the option "Search for access point".
  • The choices are given.
  • If the access point is in the form of a closed padlock gray, and the message "Security settings incompatible with the Ds" message, it means that your router is configured with security settings that the Nintendo DS does not support (WPA, WPA2, etc..).
  • The only solution is to configure your router to WEP because it is the only security that the console recognizes.
  • Sep 12, 2010 | Nintendo DS Lite Console
    How do i actually configure my DS to use wifi, and
    you need to buy a wifi system and it should come with all the codes and you need to atleast be within range of it
    May 03, 2010 | Nintendo DS Lite Console
    Connection to wi-fi
    hello there,
    here are the steps :
    • choose the option "Search for access point".
    hope this help
    Apr 15, 2010 | Nintendo DS Lite Console
    My stylus isnt working and when I try to configure the ds in goes through the process but doesnt complete...just keeps configuring
    you will need to have the digitiser screen exchanged. The part is about £2. if you know someone who can do it it's a cheap fix. Video instructions are on youtube. Not to be attempted if you aren't savy with electronics, but it's not too technical....let me know if you need more
    Jan 28, 2010 | Nintendo DS Lite Console
    I am trying to change out the shell of my nintendo ds lite and cannot get the top screen to come loose from the bottom.
    They have great manuals at www.powergamingparts.com that will show you expert pictures of how to take a DS apart. If you need more assistance please contact me.
    Sep 29, 2009 | Nintendo DS Lite Console
    US Nintendo DS-Lite with converter problems in South Africa
    It should work straight out with a step down transformer. That is of course if the mains supply in South Africa is 240 240 and the unit being American is 110.
    This is of course not unless it was initially tried without a transformer or stepdown converter which would mean that the charger/adapter has been fried and therefore damaged.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Aug 28, 2008 | Nintendo DS Console
    WiFi query
      First DS (system you are transferring the ID from)
    1. Turn on any Nintendo WFC-compatible game and access the WFC Setup Utility. (Consult the game manual for the game you are playing for specific information.)
    2. Tap "Options."
    3. Tap "Transfer Nintendo WFC Configuration."
    4. Tap "Ok", then tap "Ok" again.
    5. Second DS (system you are transferring the ID to)
    6. Remove all games from the DS you wish to transfer the settings to, then turn the system on.
    7. On the DS's main menu, select "DS Download Play."
    8. Select "Nintendo WFC Configuration Transfer."
    9. Tap "Yes" when asked if you want to download the software. The word "Downloading..." will appear.
    10. First DS
    11. On the DS with Nintendo WFC configuration, tap "Ok" to confirm that you wish to transfer the configuration.
    12. Second DS (system you are transferring the ID to)
      • If there is an existing configuration on the new DS, tap "Ok" to confirm that you wish to overwrite the existing configuration.
      • Once the transfer begins, it will take about half a minute.
      Both DS Systems
    13. Once the configuration has been transferred, tap "Ok" to save the changes and shut each system off.
    All of the Friend Codes you had given or received on the previous Nintendo DS will now work in the Nintendo DS system you transferred the ID to.
    I just copied that from nintendo.com's customer service for you... it's better than how I could explain it.
    Oct 22, 2007 | Nintendo DS Lite Console
    NINTENDO DS FELL 2 FEET AND WHEN I CHECKED IT THE TOP SCREEN WAS CRACKED IN THE BACK AND CANT SEE HALF THE SCREEN CAUSE OF THE CRACKS SO I NEED TO NOW IF YOU GUYS CAN FIX THE SCREEN OR KNOW A PLACE THAT...
    DONT ATTEMPT TO REPLACE THE TOP SCREEN ON THE DS LITE. It is easy to replace it on the original ds, But the ds lite requires you to re-soilder the 4 speaker cables into the top screen's video ribbon cable.
    Aug 03, 2007 | Nintendo DS Lite Console
    Nintendo DS Lite Console Logo
    57 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Zhenya Ogorodnikov
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
