HCL Monitor type HCM580M display problem
After complete installation of Windows XP, display is not coming on monitor while power switch is ON, if we turn OFF power switch of monitor and reset the machine. after complete loading of operating system, then we turn ON our monitor then display comes. i am facing this problem three to four system in my office, during installation display was on screen but after completion display is OFF. once again if we do switch OFF monitor and start the CPU, after complete loading of Operating System we can ON our monitor then display will come sure. if our monitor is ON already to start the CPU then display will not come
write me in detail solution please
  • Anonymous Feb 11, 2009
    Anytime I reboot the system the Power button is blue but the screen stays black. The only way to get it to work is to unplug the cord for the computer and plug it back in.
  • dave344 Mar 23, 2009
    This monitor has become flakey. The monitor screen will go black. I have to smack it around a little and sometimes I turn it on and off then it will come on. It is intermittent and it does not work more than it does work. Does any one have an answer for this?
Monitor has no display
Posted on Sep 06, 2010
Posted on Oct 13, 2009
Start Windows in SAFE mode.
To start windows in safe mode keep on pressing F8 key when you switch on computer.
Once it starts in safe mode.
Goto display properties and change resolution to minimum and restart the system.
Posted on Aug 28, 2009
  • 383 Answers
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Posted on Dec 20, 2007
LG L1730S 17" LCD Monitor
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
May 12, 2011 | LG L1730S 17" LCD Monitor
When I turn On Power the green light on th ON buttom Blinks continous. the screen does not come On.
The button should not be blinking unless it has the power led light on it which should be blinking.
Well this is an indication that there is no communication between the CPU and the monitor. Either the CPU is not working or is faulty may be because booting problem or the cables connecting the cpu to the monitor (VGA) cable is faulty.
Check them If it is the CPU with the problem, you have to check and see that all its hardware is in order i.e. well fixed. Make sure there are no loose cables in the connections.
If all these are OK, check to see that the booting order in the BIOS set up is OK. make the cd as the first booting source and the Hard Drive as the second. Disable the rest just to be sure that there is no other booting source the computer is trying to use. If it still doesn't work, reverse the boot order. Set the hard drive as the first booting source and the cd the second. If still not working, set the CD as the first booting source and then the hard drive the second and insert a bootable cd with the same operating system as the one initially used by the machine or of a higher version and boot from the machine from the cd. If you don't want to loose your files, you will go through the recovery console process
Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
  • Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
Apr 19, 2011 | Dell E198FP LCD Monitor
Monitor comes on for 2 seconds and then goes all black. What type of problem do I have?
May be you have set "Changed" the setting of your monitor power. If it's set then try this step and see whether it's helpful to you or not. In Windows 7, Vista, or XP, to change the power management settings. To change power management settings in Windows 7, Vista, or XP: Note: If this doesn't match what you see, refer to About navigation settings in Windows.
For Windows 7 and Vista From the Start menu, select Control Panel. Then choose Power Options.
From the list in the left panel, click Choose when to turn off the display or Change when the computer sleeps.
Set your options. For each action, "Turn off the display:" and "Put the computer to sleep:", you can select times ranging from 1 minute to Never.
Click Save changes.
Windows XP From the Start menu, select Settings, and then Control Panel. Double-click Power Management or Power Options. From the "Turn off monitor:" drop-down menu, select a time from After 1 min to Never. Click Apply, and then click OK.
All the Best!
Sep 15, 2010 | Computers & Internet
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Cannot display dual monitors
What is Videoadapter use ?
Use Utility to complete install with your videoadapters/
Nvidia Gforce, ATi,SIS, VIA
If your use Windows XP, Vista, go in Properties Desktop-Parameters-Advanced, and Tab (vendors video), and use many properties
Aug 20, 2009 | Sony Computers & Internet
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
Dell 2400 desktop
First, check your monitor, Is the power light on and amber?
If not , monitor is dead.
If monitor light is amber, Check the power supply fans and cpu fan. See if they are operating ok.
If monitor is coming on, fans are working, I would Pull out the adapter boards that are installed, then power on the unit. If the unit displays video, then reinstall adapters back in one at a time.
Make sure you power down when ever you remove/install anything in the PC.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 28, 2008 | Dell Dimension 2400 PC Desktop
22" flatron (W2252TQ) Monitor Will not stay on after windows logo comes on
Reboot the computer and start in safe mode.(Press F8 at start-up in WIN XP).Change display resolution to 800><600 and restart in normal mode.
Your original problem must be monitor hardware related ie some loose connection or dry solder on invertor /power board inside the monitor.
Please provide feedback and rate the solution.
Samir
Jul 25, 2008 | LG Computers & Internet
Computers & Internet Logo
1,381 people viewed this question
Alun Cox
David Payne
David Payne
