Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
