Question about Maytag Neptune MAH5500B Front Load Washer
How do I remove the drum to change the bearing in the back of the washer?
  • steve
    steve May 11, 2010
    First you go to the appliance parts supply and buy $300.00 worth of specialty tools.
    President:
  • 1,304 Answers
You cannot change the bearing it is pressed in
you nned a new tub
Posted on Oct 05, 2009
Bearing replacement
One of the biggest jobs to do on a washing machine. Remove the drum from the machine, remove the washer drum, knock out bearings, replace drum spider (shaft) fit the new bearings, and drum seal, put everything back together again. Job for a experienced engineer.
Oct 03, 2014 | Washing Machines
Spin cycle make noise
from what you wrote the signs are that the bearings have gone
Dec 17, 2013 | Indesit W 123 Front Load Washer
My washer is making noise on the spin cycle and the drum is loose inside the washer (almost like bad bearings or loose bolts?). I took off the top and the belt and motor are o.k. , but I can't get to the...
The rear drum bearing has failed, you need to remove the door seal, take off the belt, pulley and the drum comes out forwards.
Sometimes the bearings are very difficult to remove.
You will be able to find somewhere to supply the bearing there are lots of Washer spares places.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 28, 2011 | Avanti W1092F Front Load Washer
Need to change bearings
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
May 07, 2010 | Hotpoint WMA64 Front Load Washer
How to replace rear wheel bearings
If it has drum brakes, you'll need to take off the center dust cap, remove the cotter pin, remove the nut and washer holding the drum on. The outer bearing should fall out, the inner bearing usually stays in the drum, due to the grease seal. With the front bearing and washer off, put the drum back on and install the nut, then pull the drum, allowing to the nut to catch the inner bearing as you pull off the drum, and that should leave the inner bearing and seal on the spindle. Pack the new bearings with grease, install the inner one in the drum and tap in the grease seal in place, but the drum back on and install the outer bearing on the spindle, the wash, nut, cotter pin and dust cover. Tighten the nut snug and turn the drum a few times and snug up the nut. Don't overtighten it.
Apr 29, 2010 | 1991 Volkswagen Jetta
How do i remove the brake drum of a 1997 hyunidai excel do i need to remove the centre nut that also takes out the wheel bearing
With Rear Hub Bearing
  1. Raise the vehicle and support safely.
  2. Remove the wheels.
  3. Remove the dust cap, cotter pin and loosen the locknut
  4. Remove the washer and outer wheel bearing.
If the drum is difficult to remove, remove the plug from the rear of the backing plate and push the self adjuster lever away from the star wheel. Rotate the star wheel to retract the shoes.
  1. Remove the drum with the inner wheel bearing from the spindle.
To install:
  1. Install the drum on the spindle.
  2. Install the outer wheel bearing and washer.
  3. Tighten the locknut to 108-145 ft. lbs. (150-200 Nm). Turn the brake drum while tightening the spindle nut to seat the wheel bearings.
  4. Install the cotter pin and dust cap.
  5. Install the wheels
  6. Adjust the rear brakes.
Apr 23, 2010 | 1997 Hyundai Accent
Easiest way to change drum bearings
I have changed the drum bearings on our Creda Excel 1200 V120VW. Not a simple job by any means.
The machine had to be just about totally stripped to get at the drum.
Before starting beware of sharp edges on just about any part of the machine
Remove all panels, top, rear, front facia, front panel including door, motor, powder draw
The secret is to remember to take photos or make drawings of the position of all the electrical wiring, hoses, covers and any other components you may be removing for access. Keep all you components together, it saves hunting for them later or worse still not refitting them.
Once the drum is out of the washer the drive pulley has to be removed. It is secured by means of a 30mm af nut which has also been fastened with thread locking fluid. Fortunately I have an electric ratchet gun, otherwise it would have required heat on the nut to defeat the locking fluid. The pulley is also threaded and was unscrewed with the aid of an application of WD40.
The front of the outer drum is unclipped and removed, the inner drum can then be removed by replacing the nut flush with the end of the thread, to prevent damage, and tappinng the drum out with a soft faced mallet.
This done you then have to remove the old bearings and seal. This is done be means of a drift and hammer, taking care not to bruise the area where the new bearings will be fitted.
The old seal may have to be destroyed by a sharp screwdiver or a proper seal removal tool.
When the bearings are out clean all areas with fine emery, lightly grease the bearing recesses and fit the new bearings and seal. Take care when refitting the stainless drum back into the outer drum not to turn the lip on the seal.
Now it's just a simple matter of re-assembly, make sure all parts remove are re-fitted in the correct sequence.
Another tip is not to put machine and all panels, ie; top cover and rear panels, back in place until the washer has been run and tested and inspected, to make sure there are no leaks and the machine goes through the cycles as it should.
Finally good luck!!!!
May 27, 2009 | Creda W120VW Front Load Washer
Replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Jul 19, 2008 | 1999 Hyundai Sonata
Maytag Neptune MAH5500B Front Load Washer Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
