Question about Jandy Water Feature 18" Sheer Descent Extended Lip, Gray
Our waterfall stopped flowing - we called a pool service and they informed us the valve has a spring inside it and it requires replacement. We're trying to do the best we can and hope that it's not too complicated both in labor and financial.
    Champion:
  • 246 Answers
VERY EASY TURN OFF EQUIPMENT TAKE OFF SIX SCREWS REPLACE SPRING REPLACE GASKET INSERT SCREWS BACK. ALSO YOU CAN BUY A NEW VALVE AND REPLACE THE TOP ONLY ADD SILICONE TO THE GASKET. MAKE SURE EVERY THING IS CLEAN
Posted on Oct 13, 2009
DREAM MAKER SPA WATERFALL VALVE
The threaded cap the holds the waterfall valve in place is most likely cracked so you will just need a new valve. Send me a picture of it and I can see if I can locate one for you.
Jul 30, 2013 | Pool & Spa
Tip
Pentair Intelliflo Pump Alarms and Continual re-Priming
Many pool owners seem to experience the situation with the Intelliflo Variable Flo (model numbers have changed over the past 3 years) pump alarming and re-priming continually and then stopping. I had this problem for nearly two years and spoke to the actual pump designer. We ultimately solved it as there was a spring valve in the heat pump I have. Any type of spring valve (or similar item) is a problem for the intelliflo as the pump is tooooo intelligent. When the spring opens and closes with water flow (or depending on what it was designed to do) it makes the pump think that there is a blockage and it reacts by shutting off and creating an alarm.
The solution is to replace the spring valves (or item that is varying the flow in the system) in your pool circuit. I was able to create a work around that used a manual valve just before the spring valve to reduce the flow so that the spring would not move and thus impact the pump. Basically you need to be ascertain if there are any parts in your pool flow that alter the water flow and thus pressure at any time (ie such as a spring valve) as the intelligence of the pump will take that to be an irregularity and shutdown. This can be time consuming and I hope this helps.
Note: you can test the pump to confirm that it is the intelligence that is causing the fault by putting the pump into FULL manual mode - consult the manual as merely pushing the manual switch does NOT disable the fault protection and system intelligence.
on Aug 07, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Spa waterfall isn't flowing
If you turn the valve to operate the waterfall feature on your spa and no water is coming out of it, my best guess would be the valve is broken and not turning to allow the water to go to the waterfall.
Pull the top of the valve off and look inside for a broken part.
Rod
US Parts Center
888-521-6183
Feb 11, 2013 | Pentair IntelliFlo VS-3050 & VS+SVRS...
I have a Laars Lite 2 pool boiler. The gas flow does not properly stop when the thermostat hits the correct temperature, and gas is escaping wihtout being burned. I think the valve that the thermostat...
It sounds like the main gas valve is sticking open. I suggest you call a pro to repair this unless you are familiar with how to do it. Your life is worth more than a gas valve and a service call will cost you.
Aug 30, 2011 | Teledyne Laars Pool & Spa
When the spa and the waterfall running, the waterfall will **** out the water from the spa to the pool. what is wrong with this?
The valve(s) controlling water flow to all the features are not set correctly. You will need to increase the amount going back to the spa to keep it from draining. Depending on the valves in use they are not overly difficult to change the diverter settings. If you need help with that please comment to this post and include the valve brand and model number.
John
Apr 11, 2011 | Pool & Spa
I am using an AO Smith motor on a Hayward pump to run my pond. It is about 4 years old now. Most recently, in the hot weather (90+F in the Northeast) the pump just shut off as I was watching the...
pump is protected with a thermo switch made inside the motor to shut it off if it gets to hot check for oil ports at the bearings if it dose not have them maybe try adding a ball valve and turning down the flow some to create slower flow and higher pressure
Aug 31, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
New pool and keep getting code 90. intex sent a replacement system and I'm still getting code 90
code 90 indicating low flow.
Do you have a good flow from inlet to outlet? You should be shooting a pretty good stream (wave form) across the pool. You can remove the filter from the pump and run it without to see if you eliminate the error. if that works you've got some gummy filters going on that require cleaning or replacing. (daily in my case) If the error persists check the flow sensor on the chorinator. Be sure the direction is correct, the water coming into the chlorinator follows the direction on the electrolytic plate box. (usually there is arrow on this. Other thing is, how loud is the system? Are you hearing lots of air entering the intake of the pump? This can lead to air lock on the pump and little to no flow in the system. If so, bleed the air of using the relief valves at the top of the filter and at the input of the filter. Also listen to ensure that the inlet at the pool is not allowing air to be sucked into the lines. This can be due to a loose connection or bad gasket at the inlet valve of the pool.
Jun 02, 2010 | Intex Automatic Salt Water System for ...
My pump keeps getting alarms and in some cases needs to be rest at breaker if left for 5 minutes will resume
I had a similar problem for nearly two years and spoke to the actual pump designer. We ultimately solved it as there was a spring valve in the heat pump I have. Any type of spring valve is a problem for the intelliflo as the pump is tooooo intelligent. When the spring opens and closes with water flow or depending on what it was designed to do) it makes the pump think that there is a blockage and it reacts by shutting off and creating an alarm.
The solution is to replace all spring valves in your pool circuit although I was able to create a work around that used a manual valve just before the spring valve to reduce the flow so that the spring would not move and thus impact the pump. Basically you need to be ascertain if there are any parts in your pool flow that alter the water flow and thus pressure at any time (ie such as a spring valve) as the intelligence of the pump will take that to be an irregularity and shutdown. This can be time consuming and I hope this helps.
Mar 21, 2010 | Pentair IntelliFlo VS-3050 & VS+SVRS...
Jandy Water Feature 18" Sheer Descent Extended Lip, Gray   Logo
258 people viewed this question
Top Jandy Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Jandy Garden Expert? Answer questions, earn points and help others
