Question about Technics SL-1200MK2 Turntable
Power failure Plug fuse is okay but no life whatsoever. Switch seems okay, so wonder why it cut out. Any ideas?
  • 135 Answers
Usually just random failure of the 250mA fuse (F1) which is on the power input circuit board under the platter.
Posted on Jul 05, 2010
Blower not working
To determine the cause of a blower fan failure, isolate the motor, and perform some basic electrical tests.Check fuses first. Fuse failure often causes component failure. Check for power at the motor itself. Test the connection to the blower motor. Test the switch.-------------------------------------------------------------------
Car Diagnostic Tools
Dec 01, 2012 | Cars & Trucks
My optimus receiver is getting power but won't turn on
Glad you have made it!! , thanks for choosing Fixya for assistance.
Aug 30, 2012 | Audio Players & Recorders
Lifefitness 9100hr treadmill cut out
iv had similar problems, only happened once tho - i switched it on after a few mins it would go off.
iv read to dismantle the stop switch, clean and replace the microswitch. where can the microswitch be found from?
also, is the red stop switch that needs looking at? how can i remove it?
i was wondering on how i can service/maintain this properly, can anyone advise my on how to give this a service.
Jul 14, 2009 | Life Fitness 9100 Next Generation...
C21T7BA TV will not power up.
check the internal mains fuse usually connected to the mains lead via the on/off switch .good luck farr64
May 02, 2009 | Mitsubishi VS-60607 TV
No power whatsoever going to my sky box after a 12 hour power cut. Can you help
Initially, would suggest checking for a blown fuse at the rear or inside the Sky box. Your description of "no power whatsoever" indicates that the mains is not reaching the internal power supply/regulator of the box. Of course, it would also help to try the unit in another outlet.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 08, 2008 | Televison & Video
Hotpoint FFA47 no power
If the evaporator fan is not working the refrigerator will not run.
Jul 07, 2017 | Refrigerators
Magellan Roadmate 700 does not power on
Hello, Rafster! Cigarette lighter plug problems are not uncommon, and - hopefully - this is the source of your problem. Because the green LED on your plug is lit, it would suggest that the FUSE inside is okay. Still, it's worth checking! The plug is easy to open, and the fuse easy to inspect/replace. IF the fuse is okay, the cord itself or the plug end that attaches to your Roadmate could be damaged. In order to determine this, you would have to check for voltage at the output end. But, you'd need a circuit tester and a wee bit of electronics knowledge to test it. If you don't have access to a tester, then the easiest test is to simply purchase a NEW cigarette lighter cord. You can get them at most retail discount stores (BestBuy; Circuit City; WalMart; etc.); RadioShack; or directly from Magellan. They're generally less than $10.00!
Jul 20, 2007 | Magellan RoadMate 700 GPS Receiver
Dead tv
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
May 22, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Technics SL-1200MK2 Turntable Logo
119 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
