My remote is opening both my door and my neighbor's door. I think we accidently swithched them and once reporgrammed, mine opens both doors. How can I re-program it to open only my door?
  • 101 Answers
One or the other remote has an error so when you set up your remote make sure neighbor is not home ... I had this problem when my neighbor was home and I reset my remote and keypad ... later I noticed my neighbors door either opened or closed with mine I called customer support and found the neighbors sensor emitted constantly and reset to mine. ... soo Reset you remote and keypad if you have one when you neighbor is away!!! :)
Posted on Sep 29, 2009
Garage door opens by itself mostly at night.
Sounds like someone nearby has the same opener. Change your code.
Sep 01, 2015 | Building Materials
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Jan 02, 2013 | Cars & Trucks
I live in a 4-unit condo building constructed in 2008. Recently, after I trained/programed a garage door opener incorporated in a new car I purchased, I discovered that my garage door started to be...
I would recommend this. I'm not sure this will work, but I think it will.
Try starting from scratch. Reprogram the unit to the car again, I think the codes change each time it is done. If not, it's not too difficult to try.
Jan 01, 2011 | liftmaster Chamberlain Garage Door Opener...
I really need your help. My Craftsman unit model number is 139.53615SR manufactured 1/92. I have a three car garage. The original two remote controls were lost and since then I've used the setting in my...
Have your neighbor bring over his remote and open or close your door with it. Then hold the smart/learn button in for 6 seconds on your opener. Then see if he can open your door. He shouldn't be able to because that procedure erases the memory in your opener. No remotes should work. You need to get that remote #53778 back and program it and then see if your neighbor can open your door. If he can open your door at any point after you have held that button in for 6 seconds you need to get a new door opener.
Oct 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Universal garage door remote
I have a feeling your neighbor operated their door opener when you were programming your new clicker. Try erasing the memory of your opener and then program the clicker again making sure your neighbors do not operate theirs at the same time. To erase the memory hold the smart/learn button in for 10 seconds.
Jul 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programing garage door openers
Press the button on the garage door opener (red, green, or yellow) until the led starts to blink and within 10 seconds or so, ( I think it's actually 30 seconds) press the GDO control button on the remote and the opener should capture the signal and respond to it from then on. Any remotes that were set to control the opener will be wiped and the new one will be in control. There are instructions that came with the opener that show how to do this from the remote or the key-less entry. If you are talking about an in-car device then your vehicle manual may be needed too, but the main thing is to set the GDO to be looking for the code from the car remote and when you press the in-car remote the garage door should respond. If you have programmed a remote or key-less entry then it is about the same procedure.
Jun 12, 2009 | 2008 Subaru B9 Tribeca
My garage opens/close when my neighbor engages his remote control
Anytime a door opens and/or closes by itself I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
Do the above check just to be sure. If your unit is more thaan about 2 years old (freq. 390) you CAN buy an older non security plus remote and program it to your unit. this should eliminate the neighbors remote operating your door.
HOPE THIS HELPS
Feb 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
