Hi, I have a Zebra S-500, when i try to print the label the label comes out blank (white), i understand why, i don't receive any error message, the ribbon is good and also the blank label is compatible, before i don't had this problem with this label and ribbon, also the sensor see's the label because it is automatically stop at the end of the label, please someone can help me to resolve this problem.
Question, when the printer prints is there an image of the data on the ribbon when it spools onto the ribbon takeup spool? If so, the ribbon may be installed backwards. I'm sure you know what you are doing but one must check even the smallest detail when trying to solve these strange problems. If the ribbon is installed correctly and there is no image of the data on the ribbon you may be dealing with a bad printhead and the printhead needs to be replaced.
I change my unix server for windows xp and I conect a printer zebra S300,when I print ein MS DOS...
(More)
I change my unix server for windows xp and I conect a printer zebra S300,when I print ein MS DOS everthings is ok but when I try to print by windows I can´t,
I have a Zebra S500 and it was working fine. I tried to calibrate and now it is printing every other...
(More)
I have a Zebra S500 and it was working fine. I tried to calibrate and now it is printing every other label. I could not get it back where it was.
