Question about Philips 42PFP5332D 42 in. Plasma Television
TV turns on, no image, just blinks different colors
I have a Philips 42PF7320A/37. 2 days ago It went completely dark. I turned it off, waited  turned it back on and all it does now is flash an unrecognizable pattern of colors. Looks like pixels of light. No image at all. I have connected another tv in it's place with all existing equipment and it works fine. Any ideas???
  • trukssirom1 Sep 29, 2009
    Thanks for your response. I turned the TV on to capture an image to upload and the symptom has now changed to no image , no color, completely blank screen. But there what appears to be a diagnostic message of 7 blinks of a red led at the bottom left led indicator area. ??????
    Thanks for your response. I turned the TV on in an attempt to capture and upload an image of what I was seeing, and the problem symptom has changed. Now there is no blinking color on the screen at all, no image at all. there is however a diagnostic red led flashing a repeated message of 7 blinks ???????????
  • Philips Master
  • 19,396 Answers
The plasma TV is clearly faulty. The pattern of colors can depend from a faulty digital board, where video signal is generated, or from a problem in high voltage to screen.
The only way to give an opinion is seeing a picture of the color pattern.
You can upload here a picture up to 150K.
Posted on Sep 29, 2009
We have a Philips plasma 42PF7320A/37 tv. When we plug it in, all we get is a red blinking light. We took the back panel off and looked at the capacitors and they look fine. What else should we check...
cOUNT THE NUMBER OF RED BLINKS AND MAKE NOTES OF THE SEQUENCES. Third will tell tou what is wrong with the tv during it's self diagnostic.Google the make and mogel numbr and seaqrch you anwers from ther.
Jul 09, 2011 | Philips 42PF7320A 42 in. Plasma HDTV
I have a T.v. model Philips 42pf7320a/37 and my problem is that the tv red light blinks 7 times wont turn on .
All philips have the same problem you need to repalce the Ysus board check this page is call shop jimmy.com and they sell them for 139.00 and plug an play. Save money.
Thanks,
Nov 04, 2010 | Televison & Video
I just bought a philips 42" flatscreen TV model #42ef73208-37 and it won't turn on. I have a red blinking indicator light but the TV won't turn on, what can be the issue?
  • Your TV has a protective mode in case there is too much heat build-up.
  • Check the clearance around the vents of the device to be certain there are no blocking walls or cabinetswhich would limit the air flow.
  • • Check that the TV’s AC power cord is plugged into the mains socket.
    • Unplug the television, wait for 60 seconds.
    Then re-insert plug into the mains socket and turn on the television again.
If that fails take it back.. Good luck
Sep 09, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
This set is a HD plasma tv and convergence is done differently than the rear projection tv's,rear projection tv's have convergence Ic's and you can adjust the color but not on this unit.
Nov 23, 2008 | Televison & Video
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
My Plasma TV is not working any more
Sounds like a scan problem if yu suspect the y-sus i suggs\est changing the drivers to
Nov 16, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 37 flat screen
U better have it checked by a qaulified tech
Sep 09, 2007 | Initial HDTV-322 32 in. LCD Television
Philips 42PFP5332D 42 in. Plasma Television Logo
188 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
