Question about Casablanca Fan Versa Touch2 W-72 Remote Control
Casablanca fan stopped working suddenly, both fan & light
The fan has worked fine for a year and then suddenly it stopped working, both the fan and the light. We've taken it apart, replaced the receiver and reset it, disconnected the power supply and still ... nothing.
Anyone fixed this problem???
Thanks!
  • freethegerk Sep 29, 2009
    The fan is W-505 with the prime touch system. We have tested the power and it's working properly.
You must 'reset' the remote. I've had it happen quite a few times.
1. Turn off power to fan. Then back on.
2. Using remote cycle the following fan buttons from high to med to low, then from low to med to high again. That 'should' fix the problem.
Posted on Dec 30, 2009
  • 3 more comments
  • leithjim Sep 18, 2010
    As mbond24 says above, with power off to the unit, first take the battery out of the remote and push any button (gets rid of any electrical memory). Put battery back in, turn on power to the unit, then cycle from high to medium to low with about 1 second in between. I did not have to press low to high afterwards. Could be some remotes/receivers are slightly different.
  • CFancher Dec 10, 2011
    THANK YOU LEITHJIM! You're a God! Worked like a charm! If only I had known this a month ago, I wouldn't have had to live in the dark!
  • psweath Jul 22, 2012
    This solution worked great with my Casa W63 AdvanTouch remote. I cycled through the fan speeds, and then when I hit the Light button, the remote was fully functional again. I also did the first part of removing batteries and pushing buttons. Thank you for the solution!
    This solution worked great with my Casa AdvanTouch remote. After cycling through the fan speeds, hitting the light button did the trick. I also did the step of removing batteries and hitting a button or two.
  • Charlie Davis Sep 09, 2012
    Worked on my Casa W-505. Thanks for posting.
  • 101 Answers
Try to bypass remote sensor by direct wiring the fan also make sure power is reaching it you may have a power problem!!! Check wire nuts to make sure they are secure!
Posted on Sep 29, 2009
    New Friend:
  • 45 Answers
Contact FanManLighting at 1-866-600-3267. Ask for Jason, he has 21 years experience with Casa and is very familiar with prime-touch. Parts are also available at their website www.FanManLighting.com
Posted on Oct 17, 2009
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    Casablanca Trident ceiling fan issue - light suddenly stopped working - replaced bulb to no avail - fan works fine otherwise...ideas?
    Is it powered from the same breaker as the fan, check the breaker, if so check the connections. Most likely if its a pull chain switch the switch is bad,,,,, it's common..
    May 29, 2014 | Dryers
    Casablanca zephair
    The on Zephair came with the old intellouch control,which is a special control for that fan. If that is what you have then call 1-800-715-0393 with model# & serial#
    Mar 24, 2013 | Casablanca Fan 1928C Zephair Satin Brass...
    Fan has worked fine for 1 year all of a sudden, fan does not work with remote. If I turn on the outlet switch fan works at high speed only, without any control from the remote
    Take the remote aparts,clean the PCB with some Q tips with rubbbing alchahol.Check the back of the rubbers buttons back back films.If clean the PCB with some rubbing alchahol and the back films of the buttons are good.After the process,the remote should work.Not,than the reomote CPU is dead and it useless.
    Aug 26, 2010 | Casablanca Fan W-62 LCD Remote Control
    Casablanca Intellitouch Fan was working fine.. Then only the light worked and fan switch made a quick bleep and started the blades moving but then both light went off and fan stopped. Now nothing works and...
    Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
    May 15, 2010 | Casablanca Fan 3245T Ceiling
    Ceiling fan light flecker
    Grinding indicates failed bearings. This is causing excess load in the motor and that is causing the flickering. This is not a user repair and would like cost around $130.00 for labor and bearing assuming you find a shop willing to do it. Most fans have pressed bearings and are very cheap.
    Sep 02, 2017 | Casablanca Fan Stealth 3211T Ceiling
    My casablanca fan versa touch 2 does not respond to remote control - batery is fine, breaker fuse too. I recall having a same problem some time ago, forgot, how I fixed it - I know it was something with...
    I believe there is a dipswitch, and a non- dipswitch version. To sinc the remote to receiver, shut power off to the fan receiver by either a switch or breaker for about 10 minutes, turn power back on and press Hi, Medium, Low on the remote in that order. this should get them "talking" again. If this does not work, contact toll-free Jason at Fan Man Lighting 1-866-600-3267, he has 30 years experience with casablanca
    Sep 04, 2008 | Casablanca Fan Versa Touch2 W-72 Remote...
    Casablance Ceiling Fan Trouble
    itake it the light is still working if it is check the wireing from the pull switch to motor unless you have a neon live tester or volt meter thers nothing else you can check
    Jul 16, 2008 | Casablanca Fan 3245T Ceiling
    Ceiling Fan broken
    clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
    Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
    Casablanca Fan Versa Touch2 W-72 Remote Control Logo
    8,227 people viewed this question
    Top Casablanca Fan Televison & Video Experts
    deton8 von Splosion
    Are you a Casablanca Fan Televison and Video Expert? Answer questions, earn points and help others
