Question about Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Reverse Sensing System always "OFF"
2001 Explorer Limited - RSS does not default to ON as it should when shifting into reverse. If I push the on/off switch on the dash, one press does nothing (OFF light stays lit), next press the "OFF" light on the switch blinks off for about 1/3 second, then comes back on. Green light on switch never lights. Every other switch press the OFF light blinks. RSS started working by itself one time since initial failure, but is mostly off.
I disassembled and cleaned the switch contacts; no change in symptoms. I don't have wiring diagrams, and the user manual doesn't list a fuse number for RSS. Can anyone help? Thanks, ****
I had the exact same problem. It is the fuse for the brake lights ( a red 10 amp fuse) that is blown. It was the wiring in the trailer that caused it to blow. Replace that fuse and it will work perfectly!!
Posted on Apr 12, 2009
  • 1077 Answers
SOURCE: 1780 code
P1780 Park/Neutral Position Switch Malfunction (Only For A/T)
This code is related to a malfunction with the park neutral position switch, it's located on the transmission.
It maybe easier to get a Chilton manual from the autoparts store to locate the sensor/switch. The book runs about $20.
Replacing the switch/sensor may resolve the reverse light problem also.
Posted on Apr 21, 2009
  • 718 Answers
SOURCE: tail lights and reverse lights out.
Check the bulbs for the tail/brake lights. If you put in single filament bulbs it will be on from the tail light voltage and the brakes will not show.
Try this;
Turn off the lights, press the brake pedal. Look at the brightness of the brake lights.
Now turn on the lights. Look at the brightness of the lights. If is the same as before the bulbs are wrong. You need two filament bulb.
Posted on May 15, 2009
  • 776 Answers
SOURCE: My 1994 toyota Corolla will not switch out of park
There is a small plasic acess cover (1/2" x1/2") on the base of the shifter. Pry it open and press the button. You should immediately be able to shift. The button is needed because the sensor on your brake pedal is broken (won't activate your brake lights either). Use the button on your shifter to get your car home or to the mechanic so you can get the brake switch fixed. Remember whern you drive you have no brake lights. -Mark
Posted on May 29, 2011
SOURCE: no brake lights, fuses keep blowing and wont shift out of park
I just fixed my daughters car with the same problems. I found some ***** had ininstalled the tail/brake light bulb incorrectly, (that had to be hard) and the two contacts over time had started to make contact blowing the tail and stop light fuses.
Posted on Jun 28, 2012
Won't crank or come out of park
  • Neutral safety switch sends a signal to the on-board computer to allow the engine to start and to engage the transmission
  • When not replaced, vehicle may experience no start and/or transmission will not shift out of park.
Oct 15, 2015 | 2001 Pontiac Aztek
No brake lights 2001 explorer
if the signals work then the bulbs are good, as they use the same bulb. check the brake light switch under the dash at the bottom of the steering colume that the brake pedal pushes. using a test light one wire should have power all the time and the second wire should only have power when the pedal is pushed. if not then the switch is bad or out of adjustment.
Jun 20, 2015 | 2001 Ford Explorer
My 2001 Pathfinder intermittently won't crank (turn key, radio and AC come on but no engine crank). If I push/pull gear shift, it starts - is there a sensor to make sure its in Park to start that may
Many cars do have a switch on the gear shift to ensure it will not start if not in park, turn on the reverse lights when in reverse, turn on the camera when in reverse, park lights, etc. Here is an article that mentions it a little bit,
Jul 27, 2014 | 2001 Nissan Pathfinder
My 2001 Ford Explorer is giving me problems. Came home last night and it wouldn't shift into Park. It's in Reverse, but really its parked (Put the emergency brake on just in case). So N
the rubber came off on ya shift cable by transm. lay under it n look at rod that is on transm to shift cable n youll see what im saying
Mar 01, 2013 | 2001 Ford Explorer
Wont shift out of park
it is probably a problem with the ignition switch.
Jul 13, 2009 | 1996 Pontiac Grand Am
1994 ford explorer eddie
the transmission is loseing internal fluid pressure, its time for a rebuilt transmission. The A4ld that your explorer has is prone to trouble in this area. A good rebuilt transmission may cost at least $1700 dollars.
Dec 15, 2008 | 1994 Ford Explorer Limited
Reverse sensors
its a dealer issue
Jul 15, 2008 | 2004 Ford Explorer
Deactivate rss feeds
Remove it instead of adding it.
How to add RSS channel to the RSS reader (K610/K790/K800/W830/W850/Z550 series)
In order to add an RSS channel to the RSS reader do as follows: 1. Go to [MESSAGING], press "Select"
2. Scroll to [RSS READER], press "Select"
4. Enter the RSS address
5. Press [GO TO]
6. The phone will automaticaly connect with the selected page, and the RSS address will be added.
Jan 27, 2008 | Sony Ericsson K800i Cellular Phone
Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
354 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
jamie suver
Level 1 Expert
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
