Question about Escalade Toys
I have a 2003 cadillac escalade and wish to replace the rear brake pads. How do I find out if I need 1500 or 2500 series pads?
  • 557 Answers
If you call dealer parts dept. they should be able to tell you from your vin#.
Posted on Sep 29, 2009
2003 cadillac escalade brake problem
did you bleed the brakes after changing the pads?
Jul 28, 2013 | Cars & Trucks
Escalade Grinding sound coming from left front when stopping
Most likely cause would be disc brake pads grinding against brake rotor.
Mar 02, 2011 | 2005 Cadillac Escalade
I have a 2003 cadillac escalade ext and the check brake system light came on. The ABS and traction light are also on. What could be the problem?
The most likely problem is a wheel motion sensor. If your check brake light is on, you have a problem that needs immediate attention. Refer to your owners manual to see if your Escalade is still safe to drive.
Feb 28, 2011 | 2003 Cadillac Escalade Ext
How do I remove the front brake pads on 2002 escalade?
once the wheel is removed the brake caliper assembly un bolts from the steering knukle asembly and the caliper slides off the rotor. Brake pads then are simply retained by springs that are part of the pad itself. depress piston(s) completely before reassembly. clean all parts with spray brake cleaner
Sep 30, 2010 | 2002 Cadillac Escalade
My cadillac escalade esv 2003 ran out of gas when I put gas back in It now it won't start or even turnover
my cadillac escalade esv 2003 ran out of gas when I put gas back in It now it won't start or even turnover
May 24, 2010 | 2003 Cadillac Escalade Esv
How many fuel filters are on a 2003 Cadillac Escalade esv ?
There is only one fuel filter on a 2003 Cadillac, If I remember correctly the fuel filter on my 03' was on the frame rail drivers side rear and it was pretty simple to replace. You do need a fuel filter fuel line quick release tool, common to by at any parts store with the fuel filter that should be replaced every 15,000 to 25,000 miles or once a year.
Mar 05, 2010 | 2003 Cadillac Escalade Esv
Is there anything special about changing brake pads on a 2004 Escalade?
CHANGING THE BRAKE PADS IS THE SAME AS ANY OTHER CAR OR TRUCK THERE IS NOTHING DIFFERENT, MAKE SURE YOU REMOVE THE BRAKE RESEIVOIR CAP PUSH THE PISTON BACK SLOW AND REPLACE THE BRAKE PADS.
Nov 17, 2009 | 2004 Cadillac Escalade
My rear brakes seems to be locking up on my escalade,
one of your caliper piston is stuck. have it check out.
Dec 22, 2008 | 2003 Cadillac Escalade
Front wheel bearing replacement
Remove the lugs than disassemble the brake calipers remove the disc take a 3lb sledge hammer and swing it and hit the back side of where the lug studs are sticking out
Nov 20, 2008 | 2003 Cadillac Escalade
Toys Logo
Top Escalade Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you an Escalade Toy Expert? Answer questions, earn points and help others
