Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
My Liftmaster 373LM remote and wireless 377LM Keypad not working
My 373LM remote to my Model 3280 Garage Door Opener and 377LM wireless keypad started intermittently NOT working around mid-August, 2009. The one in my 2005 Camry also stopped working on the same days as the 373LM remote. It appears to be an interference problem in our area as my neighbor's also does not work on the same days/times. I have talked to various people (installer, Liftmaster, Verizon FiOs, State Representatives) and no one has any ideas other than they say it could be interference from the military transmitting at 390MHz...but my remote says it's supposed to be 315MHz. I'm at wits end! Some days it works, some days not; mostly not on weekends. Help?? I live in New Castle County, Delaware.
  • Vince Heuser May 11, 2010
    Your remote definately operates on 315mhz and the military does not use this frequency. Does the wall button still work when the remotes do not work?
  • Chris Caldwell Aug 24, 2013
    Definitely solved the problem. Remote now works from 30 yards away. Liftmaster support line never offered this solution. Thanks!
  • 118 Answers
You should have a small wire hanging down from the back of the opener. This is the remote control antenna wire. Strip off about and inch splice a wire to it. The connections is just twisting the wires together. Run the extended wire up to the ceiling and down the wall where the door is located. Most of the time in the top corners where the weather stripping is, there is a small gap. Slip the wire through the gap so the wire extends outside of the door. The key to this is getting the wire outside. 99% of the time this extension of the antenna will be enough to conquer interference issues. You are correct that you are running on 315mhz and the military will not affect it. Let me know if it helps
Posted on Jun 16, 2010
I need a remote keypad for 41a5021-1e lift master. What model will work for this unit
check the liftmaster web-site. also any garage door sites may have parts offerings. google the part number as well.
Nov 05, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
How to change code on the garage door opener and the remote control on a lift master garage door opener
If you have a 315MHZ LiftMaster Garage door opener do the following:
Follow the purple wire (Antenna) up and you will see a square purple button.
Press and hold the square purple button for ten seconds until the amber led goes out.
Press and release the purple button one time (The amber led will come on solid).
Press and hold the button on the garage door opener remote control for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
to program the wireless keypad do the following:
Enter a four digit code into the keypad then press and hold the enter button for two seconds (The light bulb on the garage door opener will blink and you will hear a click sound the amber led will go off).
Aug 08, 2014 | liftmaster Lift Master 377LM 376LM 315 MHz...
I have a chamberlain opener Model 3280. I have tried to set my three button and keypad model 976LM remotes from my old house using the learn button, but it just won't learn the remotes. I have tried...
For your hand remotes try this:
Press and hold the button down on the remote while you press and immediately release the learn button.
For the keypad:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
If this doesn't work your logic board is bad.
Jan 25, 2011 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster 3280 opens by itself occasionally. I have tested springs and they test fine.
Change the codes on the remote and of course the lifter itself, sounds as if some one in the neighborhood has programmed the same codes nearby.
Jan 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Keyless remote will not learn new 4 digit code
Press and immediately release the smart/learn button and walk over to the keypad and key in your 4 digit code and press enter. If this doesn't do the job your keypad is probably bad.
Oct 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't delete pin number from 377LM wireless keypad
The way to do this is to hold the smart/learn button in for 6 seconds. This will erase the memory and none of your remotes or keypad will work. You will have to program them all but your extra PIN will be gone.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door remotes and keypad won't hold the code.
DID YOU BUY THE KEYPAD AND REMOTES WITH THE OPENER. IT SOUNDS LIKE YOU MAY HAVE THE WRONG ONES FOR YOUR OPENER.
CHECK THE FREQ. AND IS IT ROLLING CODE.
Mar 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reprogram garage door keypad?
I have a Liftmaster 377LM wireless Keypad no maual
How do I reset it?
Jul 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Model 13553965- programming wireless keypad
You have to buy a liftmaster or craftsman keypad
May 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
1,791 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
