Question about Home
Whirlpool bath has lower then normal jet pressure
It seems to be at about a 50% capacity
    Scholar:
  • 80 Answers
This is usually caused by a reduction of RPMs of the pump. If the pump sounds slower than usual, the pump motor is worn out and needs replaced. If the pump sounds normal there could be a blockage in the impeller in the pump or a suction screen full of debris. The suction screen is at the bottom of the tub usually in the middle of one of the sides. It can usually be removed with a screwdriver and checked to make sure all the little holes are open. If none of these ideas work, call in a pro to have a proper diagnosis performed.
Posted on Oct 02, 2009
Testimonial: "Thank you for the advice, the impeller had a blockage of hair and now it works fine!!!! Thanks again, Steve"
Aker swrilbath tub want change jet colors
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Apr 06, 2013 | Whirlpool Royal A101A-R Bath Tub
Discolored jet covers
Mar 22, 2013 | Whirlpool Royal A101A-R Bath Tub
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Aug 16, 2011 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
Dec 23, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
What products to us in my jet bath
Bubble bath is definitely out of the question. Provide any of the products that you are using do not have a detergent base or bubbles so to speak, you can use them. Depending on how many times a week you use it you might want to get a cleaner that they use on hot tubs from you local pool distributer. I hope this helps you.
Nov 26, 2008 | Whirlpool Pearl Navarre 7242 True Bathtub...
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Home Logo
52 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
