Question about Lexmark P6250 All-In-One InkJet Photo Printer
I need to connect printer to new computer but do not have the cd to do this
I have lost the original dvd for setup of my cannon pixma mx396. How do I connect a new computer to the printer?
Hi
no...you don't need the original CD. Go to the Canon website and you should be able to find MX936 driver download there.
Sep 20, 2014 | Office Equipment & Supplies
Need help connecting my printer to my computerWhat's your problem?
turn off your computer. plug in your printer to power. plug the printer cord into printer and then into computer. turn on your computer. if you have the cd that came with it place it into the cd drive once the computer boots up. your computer should detect the new equipment and walk you through the set up wizard. if not go to the control panel and "add hardware" to tell your computer to detect the new equipment which will start the install wizard... good luck!
Apr 02, 2012 | Dell Computers & Internet
I want to connect my new computer to my printer
You mean connect printer to computer .
Before connecting the cables , insert the install disc in the computer drive and follow instructions . When installation os software/driver is completed , connect the USB cable to computer and printer and power cord from printer to AC plot . Press the power button and wait for Windows to confirm installation is successfull .
You can now use yoiur printer .
Best regards ,
fanaudi .
Aug 13, 2011 | HP Deskjet 2460 Printer
Need software to install hplaserjet p1006
Kindly insert the PROGRAM CD in the CD ROM drive and auto run the aplication CD without connecting the printer,in few minutes of installation progress you will get alert to connect the printer and then printer is configured by OS Above is the normal procedure,
very minute but technical tip is to
connect the printer first and insert program CD for printer in the ROM drive and open device manager and scan for hardware changes ,you will get alert on task bar that new hardware is found and new window for device installation ,click continue with browsing file path for CD in drive and continue installation ,in next few minutes your device shall be ready to use. In case there is problem with installation with CD kindly go to manufacturers website and download windows compatible drivers.
For Safe Computing Kindly keep your antivirus updated and firewall is on.
Thanks And Regards
Kindly rate this solution
Mar 03, 2010 | HP LASERJET P1006 Printer
Have new hp computer lexmark4200 wilol not printcan not understand the people on the phone with foriegn accents please help
To use a new printer on your computer, you need to install driver for that printer.
Check out there must be a setup CD/DVD shipped with your printer. If got it do the following steps.
  1. Remove all connection from printer to computer.
  2. Put the CD/DVD in computer.
  3. It will start automatically
  4. Follow the simple on screen instructions
  5. If setup display any message to connect printer, then connect your printer to computer and on it.
  6. After setup finished, you will able to use your printer.
If any problem....just Ask me
Gud luck
Iqbal
Apr 15, 2008 | Office Equipment & Supplies
No cd for cx6600
Go here to download a driver package. Click on the correct operating system, then the correct driver package. (Select a 64-bit version only if you are sure that you have a 64-bit version of your operating system.)
Generally with USB-connected printers, you will install this software package BEFORE you connect your printers USB cable to the computer.
Dec 06, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark P6250 All-In-One InkJet Photo Printer Logo
19 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
