Question about Kenmore Dryers
It takes a long time for the clothese to dry. Two
It takes a long time for the clothese to dry. Two sixty minute cycles
  • Kenmore Master
  • 3,361 Answers
If you are getting heat,remove the connecting vent on the rear of the dryer and dry a load. If it dries normally,repair the blockage in the vent.
Posted on Sep 29, 2009
What is automatic dry miser
What the automatic dry miser is, is a sensor that measure how dry the clothes are and will adjust the time its going to take to dry the clothes throughout the entire cycle. If at the beginning it estimate it will take 40 minutes to sry a load but they are dry in only 25 minutes the dryer knows the clothes are dry and cuts the dryer off. Saving 15 minutes of unneeded gas and electric that it would run and waste power and gas since the clothes were dry already.
GENE
Aug 18, 2011 | Whirlpool GGW9868K Gas Dryer
1 minute of cycle time takes 5 minutes of actual time.
Hi if this is on the sensor dry, this isnt actual time this is estimated and will vary. If its on timed dry then it should be exactly what it says. if you need further assistance let me know.
Sean
Mar 26, 2011 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
On a 40 minute drying cycle, it will have to be restarted two or three times to finish the drying cycle.
take the exsaust off the back of the dryer and dry a load
what happens does it dry better?
Aug 24, 2010 | Kenmore 700 6972 Dryer
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
Jun 17, 2010 | LG DLG7188 Gas Dryer
Have a Maytag Dependable Care dryer. Model MDG9606AWW. The glow bar comes on, gas lights and stays on about 30 seconds, go off for about 30-60 sec. then comes back on for about 10-18 seconds. Then goes off...
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Apr 01, 2010 | LG DLG5932W Gas Dryer
What is a normal wash and dry cycle for a dishwasher?
Assuming this is a residential dishwasher, the least cycle time is 18-19 minutes for light load . Average is 30-50 minutes. some have long times and super extra cyccles that will go to 70-85 minutes. Note that the drying cycle will will be the same regardless of what the wash/rinse times will be; also, the dry cyccle will be the same regardless if you use the heat switch or not. Goodluck, Macgivor
Jan 16, 2010 | Whirlpool Dishwashers
Takes too long to dry- element cycles on and off - line draw 23 amp
Clean and straighten the exhaust vent.
In fact, remove it and run a timed load for 45 minutes to verify a blocked vent problem.
Aug 12, 2009 | Whirlpool Dryers
Takes for ever to dry cloths
Remove the connecting vent from the rear of the dryer. Do a timed load a 50 minutes. If it is dry, clean out the connecting vent and the wall vent.
Jun 27, 2009 | GE Dryers
Extremely long cycle
The drying coil that is broken also heats the water during the wash and rinsing phase. Right now it is waiting for the water to heat up, that's why it's pausing. Replace broken heater, they are relatively cheap and can be gotten at repair clinic.com.
Feb 16, 2009 | Whirlpool 24 in. GU1500XTLS Stainless...
Candy Auto Sprint 1400
My auto sprint washing machine is not puping all water away and when it does work the clotheses are still wet, also does not complete cycle as lights flash so have to start al over again
Sep 14, 2008 | Candy Washing Machines
Dryers Logo
111 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
