Question about Pioneer VSX-D511 Receiver
VSX-D512 Hi, I have a Pioneer VSX-D512 receiver which I do not have the manual for. My issue is that the sound for the voices in the programs I watch is much too low and the music and bass is much too high and quite often drowns out the voices. It is common for me to sit there and have to turn up the volume when someone is speaking and turn it down when music comes on. Can someone please help. Regards, Graness
    Problem Solver:
  • 13 Answers
The best way to do this (if you haven't done this already) is to enable the Dynamic Range Control. This neat little setting makes the difference between loud and soft to be not so much, making soft sounds (like talking in your case) louder and something like explosions not so loud. This is also called Midnight Mode on some receivers. To enable this setting, grab your remote and turn the receiver on. Press the "Receiver" button, then hit the left arrow on the remote until you see something along the lines of "Dynamic range control" pop up on the LCD (should be the 8th setting). You probably want to set this to "Max", but you can also select "Mid" if you find that Max does too much.
If this still does not work, you can bump up the relative volume of the center channel a bit (or a lot of bit). Hit the "Standard" button on your remote, then "Test Tone" until "C" or "Center" comes up on the LCD. Then hit the "Level +" button a few times, making the center channel a little louder. Listen to it a while and adjust it to your liking.
The combination of these two settings should get you where you want to be. By the way, do a search on your favorite search engine for something like "manual Pioneer VSX-D512" and you should be able to download a manual from somewhere (it looks like Pioneer no longer hosts the manual on their site). Hope this helps!
Posted on Dec 20, 2007
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
Display message "DSP NG"
Hi pay attention to do all interconnections right
You can get help dowlowding a low cost service manual at link below:
http://www.smpcshop.com/VSX-D414-VSX-D512-p-5216.html
Have a nice day and Good luck
Feb 21, 2008 | Pioneer VSX-D511 Receiver
MANUAL FOR PIONEER STEREO RECEIVER MODEL VSX-D901S
Hi
Check the following link. Its athe manual for VSX D 912. May be the same for your one.
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx-d912.html
Ajin
Jan 19, 2012 | Pioneer Audio Players & Recorders
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
My Pioneer amplifier VSX-d512-s is coming up with the error message OVERLOAD and then immediately switching off. Has worked consistently for four years, this is the first problem
Sounds to me like a thermal shutdown. If it's no longer under warrenty, try opening the housing and spraying the inside with compressed air to free up any dust. Dust acts as an insulator and doesn't allow the heat to dissipate.
Beyond that, I'm not sure what else could be done without a service manual.
Oct 26, 2008 | Audio Players & Recorders
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
Actors voices
Hi....
If your system is set up for surround and you dont have a center speaker that will happen.
Check the manual for best setup
Jan 05, 2008 | Pioneer VSX-D711 Receiver
Pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Aug 03, 2007 | Pioneer VSX-D511 Receiver
Pioneer VSX-D511 Receiver Logo
357 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
