Question about Texas Instruments TI-89 Calculator
My ti-89's screen is all black for some reason. If i turn it on I can see the homepage for a second then it goes back to the black screen. How do I fix this?
  • 53 Answers
U need new batteries
Posted on Sep 29, 2009
I have a TI 89 but when I turn it on the screen is totaly black after waiting like 10minutes or so it started to brighten.
Try adjusting the screen contrast. Turn the calculator on. Press and hold the diamond key, then press + to darken or - to lighten the screen.
Jan 12, 2011 | Texas Instruments TI-89 Calculator
My TI-89 Titanium's screen froze. Well actually, the cursor kept blinking but none of the buttons worked. I got it to restart using the (-) and ) button trick, but rather than going back to normal it went...
Hi kelsers,
You need to re-install your calculator's OS. After this process your Ti 89 Titanium will operate properly. If you do the process below make sure you use new batteries.
Warning!!! If you do this procedure make sure that your computer and, calculator are connect. Use Ti Connect software and, make sure you can install the OS on the calculator without any interruption. At any time even at the very beginning of this process, if your computer or, calculator gets interrupted or you have a power failure during the installation of the OS, your calculator will be destroyed. So not attempt this procedure during a thunder storm.
You can use the Ti OS Downloader but, you will have no idea what OS is stored by the Ti OS Downloader. So, I suggest following my instructions and, installing the newest Ti 89 Titanium OS 3.10v.
Procedure to installing the newest Ti 89 Titanium OS 3.10v.
You can also get the latest copy of Ti 89 Titanium OS 3.10v by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 89 Titanium OS 3.10v." Once your at the Ti site click the Download Item, Ti 89 Titanium OS 3.10v. Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti 89 Titanium OS 3.10v. will download to you. Click, "SAVE". And then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, "Save as" to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 89 Titanium guidebook too, if needed.
Link your computer and calculator with the USB cable or, Direct Black Link cable that came with the calculator.
Remove one of the AAA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. On the older TI-89 you should see "Press I to install code...", and you should press the [9] key to continue. But, on your Ti 89 titanium it should say, "Waiting to receive..." or, "Waiting to received OS...". Now you need to follow the instructions in the paragraph below to restore the calculator's operating system.
Next, drag the Ti 89 Titanium OS 3.10v. that you copied earlier to "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Next the OS Downloader Warning will pop-up. Click, "OK" to continue and, the new OS will begin to install. The Ti Device window should pop up and, click on to the port where your Ti 89 Titanium is located, USB1 cable or Direct Black COM1. Just click, "Select" and, the OS will continue to download. Upon completion the newest Ti 89 Titanium OS 3.01v. will be installed.
Jan 10, 2011 | Texas Instruments TI-89 Calculator
My ti-89 wont turn off
if the second key is working try to reset the TI89
take out 1 battery
Hold Left Right Arrows 2nd and on
Put back the battery when the screen will reset leave the keys
this should reset the Calc if it will not help there is a problem with the hardware
Hope it will help
Dec 25, 2010 | Texas Instruments TI-89 Calculator
My TI-89 Titanium won't turn on!
A hard reset will clear all memory and should give you back control of the calculator.
1. Put the batteries in the calculator.
2. Press and hold left arrow, right arrow, and 2nd keys.
3. Press and release ON.
Jan 15, 2010 | Texas Instruments TI-89 Calculator
How do you fix a TI-89 calculator whose screen is half dark?
Nov 11, 2009 | Texas Instruments TI-89 Calculator
Full Black Screen
Maybe the contrast setting is off, try holding diamond (green key) and pressing the + and - keys multiple times.
Mar 30, 2009 | Texas Instruments TI-89 Calculator
Screen fully black
Black-Screen/Black-Pixel Fix for TI-Calculator
This will erase all memory and reset defaults.
1. Remove 1 AAA Battery
2. Press and Hold 'ON' for 30 seconds
3. Replace AAA Battery
4. Adjust Contrast to appropriate level
If this fails, try again with ALL Batteries removed including
the backup Lithium Battery.
If all else fails, try the following reset procedure:
1. Remove ALL Batteries (inc. Backup)
2. Let Calculator sit with no batteries for 2~4 hours.
3. Hold 'ON' for 30 seconds.
4. Replace all the batteries (May be good idea to use new batteries
just in case old ones were dead)
5. Turn on Calculator
6. Change Contrast to appropriate level
- Remember to use correct batteries or calculator may not work. The
correct batteries are Alkaline, Rechargable Batteries are TOO WEAK,
Heavy Duty batteries are TOO STRONG.
Oct 09, 2008 | Texas Instruments TI-89 Calculator
"Adress Error"
reinstall the OS?
go to education.ti.com and download the operating system (AMS) for Ti-89 Titanium?
Sep 23, 2008 | Texas Instruments TI-89 Calculator
Screen Solid Balck
Hey, if this is a ti-89, press green diamond button, then -, keep going and it soguld fix itself
Sep 01, 2007 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
546 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
