Question about Texas Instruments TI-89 Calculator
I can't get the answer in decimal form. Need to convert from DMS to decimal.
  • Texas Instru... Master
  • 7,993 Answers
Use [2nd][MATH][2:Angle] [9:-->DD] [ENTER][ENTER] . To have meaningful results make sure angle unit is in degrees.
Hope it helps.
Posted on Sep 29, 2009
How can i convert degrees,minutes and seconds to decimal degrees in a casio fx-82MS
Use the DMS key marked degree, apostrophe, double quotation mark.
Lets us call it [DMS]
To enter an angle in degree minutes seconds or hour, minutes, seconds, type in the number of degrees, press the [DMS] key, enter the number of seconds, press the [DMS] key, enter the number of seconds then the [DMS] key. Press = the calculator displays the value in DMS units. If you press the DMS key again the number displayed is converted to decimal degrees.
Example:enter 12 degrees, 15 minutes, and 25 seconds
12 [DMS]15[DMS]25[DMS] =
Calculator displays 12 deg 15'25"
Press the DMS key again and you see 12.2569444
Feb 19, 2013 | Casio FX-82MS Scientific Calculator
How do i enter 50deg,25minutes,23seconds into a casio fx-9750 plus
In Run>Mat press the OPTN key, Then F6:> to move to the next page of options. You will see the ANGL tab as on the screen capture (above F5 key.
Press F5. You will see what follows.
Type in 50, press the F4 key, 25 then F4, 23 then F4. Press EXE. you get the result in decimal degrees as on the screen capture. To convert from DMS to D.D, or from D.D to DMS, vice-versa, press the F5 key
Jan 05, 2013 | Casio FX-9750GPlus Calculator
How do i go from dms to decimal degrees with my ti-30x IIs
Press the key that is marked with a small circle, an apostrophe, and a double quotation mark. That is the DMS key. You can use it to convert from Decimal degress to DMS and back.
Oct 27, 2011 | Texas Instruments TI-30XA Calculator
I know how to convert between decimal degress and degrees, minutes, seconds, but how do you enter degrees, minutes, and seconds directly?
Enter it as DD.MMSS and then press 2nd [DMS-DD] to convert it to decimal for further calculations.
For example, to enter 21 degrees 34 minutes 45 seconds, enter 21.3445 then press 2nd [DMS-DD].
May 12, 2011 | Texas Instruments TI-30XA Calculator
How do you convert dms to dd on a ti-30xa calculater
Enter in your dms value in decimal form (ex. 48 (degrees) 5' 3.5" as 48.05035), then press [2nd] [dms > dd] and hit enter.
Feb 24, 2011 | Texas Instruments TI-30XA Calculator
How do i convert a degrees/minutes/second problem using the Casio Fx-115ES calculator? Can you provide an example? Thanks ZH
Use the key above the ENG key to enter a value in DMS form, ending each portion with the key. To convert it to decimal, press SD once (or twice if you get a fraction the first time).
Example: sine of 12 degrees 15 minutes:
sin 12 *** 15 *** =
where *** is the DMS key.
Sep 25, 2010 | Casio FX-115ES Scientific Calculator
T-85 d.ms to dec degrees
To convert a value in DMS form to decimal, use the degree command in the MATH ANGLE MENU.
2ND [MATH] F3 to bring up the menu. The degree command is F1. F4 converts back to DMS.
Sep 02, 2010 | Texas Instruments TI-85 Calculator
HOW DO YOU USE THE DEGREES MINUTE SECONDS FUNCTION
To convert an angle from degrees (decimal degrees) to the sexagesimal notation (deg, min, seconds) use the key [DMS] the one between [(-) and [hyp].
Everytime you press the key, the displayed result is cast in the other form
EX; 12.58 [DMS] gives 12 deg 34 min 48 sec.
Suggestion: If you are doing many calculations with the sexagesimal format, use the decimal degree format, and only when you find the final result do you convert it to DMS.
Hope it helps.
Sep 30, 2009 | Casio FX-115ES Scientific Calculator
Convert degrees and minutes to decimal degrees
In the main menu screen press the Action menu, then Transformation submenu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
Hope it helps.
Jul 13, 2009 | Casio ClassPad 300 Calculator
Degrees, minutes, seconds converted to decimal degrees
No DMS button
1degree 22.25 minutes
2nd Math F3 1 F1 22 f3 15 f3 enter
Sep 05, 2008 | Texas Instruments TI-85 Calculator
Texas Instruments TI-89 Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
